[postgis-tickets] [PostGIS] #3657: Fix winnie badge on the wiki table for 2.3 branch
trac at osgeo.org
Thu Jan 5 11:15:23 PST 2017
Reporter: strk | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.3.1
Component: buildbots | Version: 2.3.x
Resolution: fixed | Keywords:
Comment (by robe):
In [changeset:"15280" 15280]:
#!CommitTicketReference repository="" revision="15280"
Relationship functions not using an index in some cases
Set cost back to 1 for functions that return a geometry
A higher cost has the side-effect of making the planner
think when used in conjunction with relate constructs like ST_Intersects
it's cheaper to compute the geometry once rather
than compute twice and break into an index and non-index call.
References #3657 for PostGIS 2.3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3657#comment:9>
