[postgis-tickets] [PostGIS] #3689: Your "Right Hand Rule" is wrong
PostGIS trac at osgeo.org
Fri Jan 20 07:31:17 PST 2017
  Reporter:  jyutzler  |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.3.2
 Component:  postgis   |    Version:  2.3.x
Resolution:            |   Keywords:
Comment (by dbaston):
 I did some work to put together `ST_IsCW` and `ST_IsCCW` to address the
 dependency of `ST_Orientation` on SFGCAL (#3651, not committed); I could
 include `ST_ForceCW` and `ST_ForceCCW` in the same changeset and put it up
 as a PR for review.
 We could also put a note on the doc for `ST_ForceRHR` noting that the
 definition of the RHR, as described in the doc, conflicts with the
 definition in some other sources such as the GeoJSON spec.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3689#comment:7>
