[postgis-tickets] [PostGIS] #3694: regress_selectivity failing on PostgreSQL 10dev
trac at osgeo.org
Sat Jan 21 23:15:13 PST 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: postgresql 10 |
PostgreSQL 10devel on x86_64-pc-linux-gnu, compiled by gcc (Debian
5.2.1-22) 5.2.1 20151010, 64-bit
Postgis 2.4.0dev - r15288 - 2017-01-21 22:03:13
scripts 2.4.0dev r15288
GEOS: 3.6.2dev-CAPI-1.10.2 r4327
PROJ: Rel. 4.9.2, 08 September 2015
SFCGAL: 1.3.0
regress_selectivity .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_63_diff)
--- regress_selectivity_expected 2017-01-01 03:28:18.655591934
+0000
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_63_out
2017-01-21 22:05:28.847702075 +0000
@@ -2,16 +2,16 @@
ERROR: stats for "no_stats.g" do not exist
ERROR: stats for "no_stats_join.g" do not exist
-selectivity_00|2127
-selectivity_01|1068
+selectivity_00|715
+selectivity_01|245
selectivity_02|actual|0.502
-selectivity_03|estimated|0.502
-selectivity_04|161
+selectivity_03|estimated|0.638
+selectivity_04|55
selectivity_05|actual|0.076
-selectivity_06|estimated|0.076
+selectivity_06|estimated|0.119
selectivity_07|81
selectivity_08|actual|0.038
-selectivity_09|estimated|0.038
+selectivity_09|estimated|0.231
selectivity_10|actual|0
selectivity_10|actual|1
and knn_recheck sadly is still failing
knn_recheck .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_94_diff)
--- knn_recheck_expected 2017-01-07 22:06:57.264893099 +0000
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_94_out
2017-01-21 22:06:23.531704180 +0000
@@ -13,8 +13,8 @@
#3|1|147|9.6598|9.6598
#3|1|291|10.8780|10.8780
#3|1|292|13.4929|13.4929
-#3|500003|500004|1447.7424|1447.7424
#3|500003|500002|1447.7424|1447.7424
+#3|500003|500004|1447.7424|1447.7424
#3|500003|500001|3423.4486|3423.4486
#3|500003|500005|3423.4486|3423.4486
#3|500003|22837|5123.7770|5123.7770
@@ -59,7 +59,7 @@
#2g|30695|21264.3654|21264.3654
#2g|30512|25313.2118|25313.2118
#3g|1000|t
-#3g|2614|t
+#3g|2614|f
#3g|500000|t
#1g|500000|0.0000|0.0000
#1g|600003|69974.6935|69974.6935
@@ -72,7 +72,7 @@
#3g|1000|t
-#3g|2614|t
+#3g|2614|f
#3g|500000|t
#1nd-3|290|260.6797|260.6797
#1nd-3|287|264.3000|264.3000
@@ -89,10 +89,10 @@
#3nd-3|1|294|9.6598|9.6598
#3nd-3|1|582|10.8780|10.8780
#3nd-3|1|583|13.4929|13.4929
-#3nd-3|500003|500004|1448.3262|1448.3262
#3nd-3|500003|500002|1448.3262|1448.3262
-#3nd-3|500003|500001|3424.9088|3424.9088
+#3nd-3|500003|500004|1448.3262|1448.3262
#3nd-3|500003|500005|3424.9088|3424.9088
+#3nd-3|500003|500001|3424.9088|3424.9088
#3nd-3|500003|45674|5153.7747|5153.7747
#3nd-3|600001|600002|0.0000|0.0000
#3nd-3|600001|9752|54.2730|54.2730
Looks like selectivity started failing around January 18th.
This is the log of the PostgreSQL of the first run we see where it fails.
{{{ git revision: 69f4b9c85f168ae006929eec44fc44d569e846b9
Build #1867 (Jan 18, 2017 9:54:34 PM)
add description
Subproject Builds
Changes
Avoid use of DROP TABLE .. CASCADE in partitioning tests. (detail)
Disable transforms that replaced AT TIME ZONE with RelabelType.
(detail)
Implement array version of jsonb_delete and operator (detail)
Change some test macros to return true booleans (detail)
Reset the proper GUC in create_index test. (detail)
Improve comment in hashsearch.c. (detail)
Move targetlist SRF handling from expression evaluation to new
executor (detail)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3694>
