[postgis-tickets] r15291 - Fix for pg_upgrade of pg < 9.5 + 2.3+, pg_upgrade and doing a postgis micro update to latest stable.
Regina Obe
lr at pcorp.us
Sat Jan 21 23:44:50 PST 2017
Author: robe
Date: 2017-01-21 23:44:49 -0800 (Sat, 21 Jan 2017)
New Revision: 15291
Added:
branches/2.3/postgis/geography_brin.sql.in
branches/2.3/postgis/postgis_brin.sql.in
branches/2.3/postgis/geography.sql.in
branches/2.3/postgis/postgis.sql.in
closes #3683 for PostGIS 2.3
Modified: branches/2.3/postgis/geography.sql.in
--- branches/2.3/postgis/geography.sql.in 2017-01-22 05:46:18 UTC (rev 15290)
+++ branches/2.3/postgis/geography.sql.in 2017-01-22 07:44:49 UTC (rev 15291)
@@ -286,94 +286,9 @@
FUNCTION 6 geography_gist_picksplit (internal, internal),
FUNCTION 7 geography_gist_same (box2d, box2d, internal);
-#if POSTGIS_PGSQL_VERSION > 94
--- BRIN support for geographies --
+-- moved to separate file cause its invovled
+#include "geography_brin.sql.in"
--- the needed cross-operators --
--- Availability: 2.3.0
-CREATE OR REPLACE FUNCTION overlaps_geog(gidx, geography)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_gidx_geog_overlaps'
-LANGUAGE 'c' IMMUTABLE STRICT;
-CREATE OR REPLACE FUNCTION overlaps_geog(gidx, gidx)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_gidx_gidx_overlaps'
-CREATE OPERATOR && (
- LEFTARG = gidx,
- RIGHTARG = geography,
- PROCEDURE = overlaps_geog,
- COMMUTATOR = &&
-CREATE OR REPLACE FUNCTION overlaps_geog(geography, gidx)
-RETURNS boolean
-AS $$
- SELECT $2 OPERATOR(@extschema at .&&) $1;
-$$ LANGUAGE SQL IMMUTABLE STRICT;
- LEFTARG = geography,
- RIGHTARG = gidx,
- COMMUTATOR = &&
- LEFTARG = gidx,
- RIGHTARG = gidx,
- COMMUTATOR = &&
--- the OpFamily --
-CREATE OPERATOR FAMILY brin_geography_inclusion_ops USING brin;
-CREATE OR REPLACE FUNCTION geog_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
- AS 'MODULE_PATHNAME','geog_brin_inclusion_add_value'
- LANGUAGE 'c';
-CREATE OPERATOR CLASS brin_geography_inclusion_ops
- DEFAULT FOR TYPE geography
- USING brin
- FAMILY brin_geography_inclusion_ops AS
- OPERATOR 3 &&(geography, geography),
- FUNCTION 1 brin_inclusion_opcinfo(internal) ,
- FUNCTION 2 geog_brin_inclusion_add_value(internal, internal, internal, internal) ,
- FUNCTION 3 brin_inclusion_consistent(internal, internal, internal) ,
- FUNCTION 4 brin_inclusion_union(internal, internal, internal) ,
- STORAGE gidx;
-ALTER OPERATOR FAMILY brin_geography_inclusion_ops USING brin ADD
- OPERATOR 3 &&(gidx, geography),
- OPERATOR 3 &&(geography, gidx),
- OPERATOR 3 &&(gidx, gidx);
--- END
-#endif
-- B-Tree Functions
-- For sorting and grouping
Added: branches/2.3/postgis/geography_brin.sql.in
--- branches/2.3/postgis/geography_brin.sql.in (rev 0)
+++ branches/2.3/postgis/geography_brin.sql.in 2017-01-22 07:44:49 UTC (rev 15291)
@@ -0,0 +1,104 @@
+#if POSTGIS_PGSQL_VERSION > 94
+-- BRIN support for geographies --
+-- the needed cross-operators --
+-- Availability: 2.3.0
+CREATE OR REPLACE FUNCTION overlaps_geog(gidx, geography)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_gidx_geog_overlaps'
+LANGUAGE 'c' IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION overlaps_geog(gidx, gidx)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_gidx_gidx_overlaps'
+-- logic to create missing brin operators
+-- note we can't use CREATE IF NOT EXISTS since not currently supported for operators or families
+-- an earlier 2.3+ might miss this if doing upgrade from < 9.5 to 9.5+
+-- so we need to include this always for 9.5+
+-- Intentionally not indenting DDL cause our uninstall process can't pick it up
+-- also not dollar quoting functions inside DO since gets tripped up by perl upgrade script parser
+DO language 'plpgsql' $$
+BEGIN
+ -- add geography brin ops if missing and are running a newer than 9.4 --
+ -- use wildcard since if schema postgis is installed is not in search path, will have schema name in front
+ IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '&&' AND
+ oprleft::regtype::text LIKE '%gidx' AND oprright::regtype::text LIKE '%geography' ) THEN
+CREATE OPERATOR && (
+ LEFTARG = gidx,
+ RIGHTARG = geography,
+ PROCEDURE = overlaps_geog,
+ COMMUTATOR = &&
+CREATE OR REPLACE FUNCTION overlaps_geog(geography, gidx)
+RETURNS boolean
+AS
+ 'SELECT $2 OPERATOR(@extschema at .&&) $1;'
+ LANGUAGE SQL IMMUTABLE STRICT;
+ LEFTARG = geography,
+ RIGHTARG = gidx,
+ COMMUTATOR = &&
+ LEFTARG = gidx,
+ RIGHTARG = gidx,
+ COMMUTATOR = &&
+-- the OpFamily --
+CREATE OPERATOR FAMILY brin_geography_inclusion_ops USING brin;
+CREATE OR REPLACE FUNCTION geog_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
+ AS 'MODULE_PATHNAME','geog_brin_inclusion_add_value'
+ LANGUAGE 'c';
+CREATE OPERATOR CLASS brin_geography_inclusion_ops
+ DEFAULT FOR TYPE geography
+ USING brin
+ FAMILY brin_geography_inclusion_ops AS
+ OPERATOR 3 &&(geography, geography),
+ FUNCTION 1 brin_inclusion_opcinfo(internal) ,
+ FUNCTION 2 geog_brin_inclusion_add_value(internal, internal, internal, internal) ,
+ FUNCTION 3 brin_inclusion_consistent(internal, internal, internal) ,
+ FUNCTION 4 brin_inclusion_union(internal, internal, internal) ,
+ STORAGE gidx;
+ALTER OPERATOR FAMILY brin_geography_inclusion_ops USING brin ADD
+ OPERATOR 3 &&(gidx, geography),
+ OPERATOR 3 &&(geography, gidx),
+ OPERATOR 3 &&(gidx, gidx);
+ END IF;
+END;
+-- END
+#endif
\ No newline at end of file
Modified: branches/2.3/postgis/postgis.sql.in
--- branches/2.3/postgis/postgis.sql.in 2017-01-22 05:46:18 UTC (rev 15290)
+++ branches/2.3/postgis/postgis.sql.in 2017-01-22 07:44:49 UTC (rev 15291)
@@ -5569,302 +5569,10 @@
AS 'MODULE_PATHNAME', 'ST_InterpolatePoint'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
--- BRIN support --
+#include "postgis_brin.sql.in"
--- 2d operators --
-CREATE OR REPLACE FUNCTION contains_2d(box2df, geometry)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_contains_box2df_geom_2d'
-CREATE OR REPLACE FUNCTION is_contained_2d(box2df, geometry)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_within_box2df_geom_2d'
-CREATE OR REPLACE FUNCTION overlaps_2d(box2df, geometry)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_overlaps_box2df_geom_2d'
-CREATE OR REPLACE FUNCTION overlaps_2d(box2df, box2df)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_contains_box2df_box2df_2d'
-CREATE OR REPLACE FUNCTION contains_2d(box2df, box2df)
-RETURNS boolean
-CREATE OR REPLACE FUNCTION is_contained_2d(box2df, box2df)
-RETURNS boolean
-CREATE OPERATOR ~ (
- LEFTARG = box2df,
- RIGHTARG = geometry,
- PROCEDURE = contains_2d,
- COMMUTATOR = @
-CREATE OPERATOR @ (
- LEFTARG = box2df,
- PROCEDURE = is_contained_2d,
- COMMUTATOR = ~
- LEFTARG = box2df,
- PROCEDURE = overlaps_2d,
- COMMUTATOR = &&
-CREATE OR REPLACE FUNCTION contains_2d(geometry, box2df)
-RETURNS boolean
-AS $$
- SELECT $2 @ $1;
-CREATE OR REPLACE FUNCTION is_contained_2d(geometry, box2df)
-RETURNS boolean
-AS $$
- SELECT $2 ~ $1;
-CREATE OR REPLACE FUNCTION overlaps_2d(geometry, box2df)
-RETURNS boolean
-AS $$
- LEFTARG = geometry,
- RIGHTARG = box2df,
- COMMUTATOR = @,
- COMMUTATOR = ~,
- COMMUTATOR = &&
- LEFTARG = box2df,
- COMMUTATOR = &&
- LEFTARG = box2df,
- COMMUTATOR = ~
- LEFTARG = box2df,
- COMMUTATOR = @
--- nd operators --
-CREATE OR REPLACE FUNCTION overlaps_nd(gidx, geometry)
-RETURNS boolean
-AS 'MODULE_PATHNAME','gserialized_gidx_geom_overlaps'
-CREATE OR REPLACE FUNCTION overlaps_nd(gidx, gidx)
-RETURNS boolean
-CREATE OPERATOR &&& (
- LEFTARG = gidx,
- PROCEDURE = overlaps_nd,
- COMMUTATOR = &&&
-CREATE OR REPLACE FUNCTION overlaps_nd(geometry, gidx)
-RETURNS boolean
-AS $$
- SELECT $2 OPERATOR(@extschema at .&&&) $1;
- RIGHTARG = gidx,
- COMMUTATOR = &&&
- LEFTARG = gidx,
- RIGHTARG = gidx,
- COMMUTATOR = &&&
--- Create operator families --
--- 2D case --
-CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_2d USING brin;
-CREATE OR REPLACE FUNCTION geom2d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
- AS 'MODULE_PATHNAME','geom2d_brin_inclusion_add_value'
- LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geom3d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
- AS 'MODULE_PATHNAME','geom3d_brin_inclusion_add_value'
- LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geom4d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
- AS 'MODULE_PATHNAME','geom4d_brin_inclusion_add_value'
- LANGUAGE 'c';
-CREATE OPERATOR CLASS brin_geometry_inclusion_ops_2d
- DEFAULT FOR TYPE geometry
- USING brin
- FAMILY brin_geometry_inclusion_ops_2d AS
- OPERATOR 3 &&(geometry, geometry),
- OPERATOR 7 ~(geometry, geometry),
- OPERATOR 8 @(geometry, geometry),
- FUNCTION 2 geom2d_brin_inclusion_add_value(internal, internal, internal, internal) ,
- STORAGE box2df;
-ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_2d USING brin ADD
- OPERATOR 3 &&(box2df, geometry),
- OPERATOR 7 ~(box2df, geometry),
- OPERATOR 8 @(box2df, geometry),
- OPERATOR 3 &&(geometry, box2df),
- OPERATOR 7 ~(geometry, box2df),
- OPERATOR 8 @(geometry, box2df),
- OPERATOR 3 &&(box2df, box2df),
- OPERATOR 7 ~(box2df, box2df),
- OPERATOR 8 @(box2df, box2df);
--- 3D case --
-CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_3d USING brin;
-CREATE OPERATOR CLASS brin_geometry_inclusion_ops_3d
- FOR TYPE geometry
- USING brin
- FAMILY brin_geometry_inclusion_ops_3d AS
- OPERATOR 3 &&&(geometry, geometry),
- FUNCTION 2 geom3d_brin_inclusion_add_value(internal, internal, internal, internal) ,
- STORAGE gidx;
-ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_3d USING brin ADD
- OPERATOR 3 &&&(gidx, geometry),
- OPERATOR 3 &&&(geometry, gidx),
- OPERATOR 3 &&&(gidx, gidx);
--- 4D case --
-CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_4d USING brin;
-CREATE OPERATOR CLASS brin_geometry_inclusion_ops_4d
- FOR TYPE geometry
- USING brin
- FAMILY brin_geometry_inclusion_ops_4d AS
- FUNCTION 2 geom4d_brin_inclusion_add_value(internal, internal, internal, internal) ,
- STORAGE gidx;
-ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_4d USING brin ADD
--- END
-#endif
-- USER CONTRIBUTED
Added: branches/2.3/postgis/postgis_brin.sql.in
--- branches/2.3/postgis/postgis_brin.sql.in (rev 0)
+++ branches/2.3/postgis/postgis_brin.sql.in 2017-01-22 07:44:49 UTC (rev 15291)
@@ -0,0 +1,336 @@
+#include "sqldefines.h"
+-- BRIN support start --
+-- 2d operators --
+CREATE OR REPLACE FUNCTION contains_2d(box2df, geometry)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_contains_box2df_geom_2d'
+CREATE OR REPLACE FUNCTION is_contained_2d(box2df, geometry)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_within_box2df_geom_2d'
+CREATE OR REPLACE FUNCTION overlaps_2d(box2df, geometry)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_overlaps_box2df_geom_2d'
+CREATE OR REPLACE FUNCTION overlaps_2d(box2df, box2df)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_contains_box2df_box2df_2d'
+CREATE OR REPLACE FUNCTION contains_2d(box2df, box2df)
+RETURNS boolean
+CREATE OR REPLACE FUNCTION is_contained_2d(box2df, box2df)
+RETURNS boolean
+BEGIN
+ -- add geometry brin ops if missing and are running a newer than 9.4 --
+ -- use wildcard since if schema postgis is installed in is not in search path, will have schema name in front
+ IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '~' AND
+ oprleft::regtype::text LIKE '%box2df' AND oprright::regtype::text LIKE '%geometry' ) THEN
+CREATE OPERATOR ~ (
+ LEFTARG = box2df,
+ RIGHTARG = geometry,
+ PROCEDURE = contains_2d,
+ COMMUTATOR = @
+ END IF;
+ IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '@' AND
+CREATE OPERATOR @ (
+ LEFTARG = box2df,
+ PROCEDURE = is_contained_2d,
+ COMMUTATOR = ~
+ LEFTARG = box2df,
+ PROCEDURE = overlaps_2d,
+ COMMUTATOR = &&
+CREATE OR REPLACE FUNCTION contains_2d(geometry, box2df)
+RETURNS boolean
+AS
+ 'SELECT $2 OPERATOR(@extschema at .@) $1;'
+LANGUAGE SQL IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION is_contained_2d(geometry, box2df)
+RETURNS boolean
+AS
+ 'SELECT $2 OPERATOR(@extschema at .~) $1;'
+CREATE OR REPLACE FUNCTION overlaps_2d(geometry, box2df)
+RETURNS boolean
+AS
+ LEFTARG = geometry,
+ RIGHTARG = box2df,
+ COMMUTATOR = @,
+ COMMUTATOR = ~,
+ COMMUTATOR = &&
+ LEFTARG = box2df,
+ COMMUTATOR = &&
+ LEFTARG = box2df,
+ COMMUTATOR = ~
+ LEFTARG = box2df,
+ COMMUTATOR = @
+ END IF;
+-- nd operators --
+CREATE OR REPLACE FUNCTION overlaps_nd(gidx, geometry)
+RETURNS boolean
+AS 'MODULE_PATHNAME','gserialized_gidx_geom_overlaps'
+CREATE OR REPLACE FUNCTION overlaps_nd(gidx, gidx)
+RETURNS boolean
+ IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '&&&' AND
+ oprleft::regtype::text LIKE '%gidx' AND oprright::regtype::text LIKE '%geometry' ) THEN
+CREATE OPERATOR &&& (
+ LEFTARG = gidx,
+ PROCEDURE = overlaps_nd,
+ COMMUTATOR = &&&
+CREATE OR REPLACE FUNCTION overlaps_nd(geometry, gidx)
+RETURNS boolean
+AS
+ 'SELECT $2 OPERATOR(@extschema at .&&&) $1;'
+ RIGHTARG = gidx,
+ COMMUTATOR = &&&
+ LEFTARG = gidx,
+ RIGHTARG = gidx,
+ COMMUTATOR = &&&
+ END IF;
+ -- Create operator families --
+ -- 2D case --
+ IF NOT EXISTS(SELECT 1 FROM pg_opfamily WHERE opfname = 'brin_geometry_inclusion_ops_2d') THEN
+CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_2d USING brin;
+ END IF;
+CREATE OR REPLACE FUNCTION geom2d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
+ AS 'MODULE_PATHNAME','geom2d_brin_inclusion_add_value'
+ LANGUAGE 'c';
+CREATE OR REPLACE FUNCTION geom3d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
+ AS 'MODULE_PATHNAME','geom3d_brin_inclusion_add_value'
+ LANGUAGE 'c';
+CREATE OR REPLACE FUNCTION geom4d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
+ AS 'MODULE_PATHNAME','geom4d_brin_inclusion_add_value'
+ LANGUAGE 'c';
+ IF NOT EXISTS(SELECT 1 FROM pg_opclass WHERE opcname = 'brin_geometry_inclusion_ops_2d') THEN
+CREATE OPERATOR CLASS brin_geometry_inclusion_ops_2d
+ DEFAULT FOR TYPE geometry
+ USING brin
+ FAMILY brin_geometry_inclusion_ops_2d AS
+ OPERATOR 3 &&(geometry, geometry),
+ OPERATOR 7 ~(geometry, geometry),
+ OPERATOR 8 @(geometry, geometry),
+ FUNCTION 2 geom2d_brin_inclusion_add_value(internal, internal, internal, internal) ,
+ STORAGE box2df;
+ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_2d USING brin ADD
+ OPERATOR 3 &&(box2df, geometry),
+ OPERATOR 7 ~(box2df, geometry),
+ OPERATOR 8 @(box2df, geometry),
+ OPERATOR 3 &&(geometry, box2df),
+ OPERATOR 7 ~(geometry, box2df),
+ OPERATOR 8 @(geometry, box2df),
+ OPERATOR 3 &&(box2df, box2df),
+ OPERATOR 7 ~(box2df, box2df),
+ OPERATOR 8 @(box2df, box2df);
+ END IF;
+ -- 3D case --
+ IF NOT EXISTS(SELECT 1 FROM pg_opfamily WHERE opfname = 'brin_geometry_inclusion_ops_3d') THEN
+CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_3d USING brin;
+ END IF;
+ IF NOT EXISTS(SELECT 1 FROM pg_opclass WHERE opcname = 'brin_geometry_inclusion_ops_3d') THEN
+CREATE OPERATOR CLASS brin_geometry_inclusion_ops_3d
+ FOR TYPE geometry
+ USING brin
+ FAMILY brin_geometry_inclusion_ops_3d AS
+ OPERATOR 3 &&&(geometry, geometry),
+ FUNCTION 2 geom3d_brin_inclusion_add_value(internal, internal, internal, internal) ,
+ STORAGE gidx;
+ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_3d USING brin ADD
+ OPERATOR 3 &&&(gidx, geometry),
+ OPERATOR 3 &&&(geometry, gidx),
+ OPERATOR 3 &&&(gidx, gidx);
+ END IF;
+ -- 4D case --
+ IF NOT EXISTS(SELECT 1 FROM pg_opfamily WHERE opfname = 'brin_geometry_inclusion_ops_4d') THEN
+CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_4d USING brin;
+CREATE OPERATOR CLASS brin_geometry_inclusion_ops_4d
+ FOR TYPE geometry
+ USING brin
+ FAMILY brin_geometry_inclusion_ops_4d AS
+ FUNCTION 2 geom4d_brin_inclusion_add_value(internal, internal, internal, internal) ,
+ STORAGE gidx;
+ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_4d USING brin ADD
+ END IF;
+-- END
+END;
+-- BRIN support end
+#endif
