[postgis-tickets] [PostGIS] #3688: ST_AsLatLonText does not round numbers as expected
PostGIS trac at osgeo.org
Tue Jan 24 11:45:16 PST 2017
  Reporter:  mwtoews    |      Owner:  strk
      Type:  defect     |     Status:  reopened
  Priority:  medium     |  Milestone:  PostGIS 2.3.2
 Component:  liblwgeom  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 This seems to be triggering an eror on winnie. I'm rerunning now but at
 least for trunk been getting this on the 9.3 run:
 Suite: printing
   Test: test_lwprint_default_format ...
 Assert failed:
         76°35'60.000"S 76°35'60.000"E (actual)
         76°36'0.000"S 76°36'0.000"E   (expected)
 FAILED
     1. cu_print.c:33  - CU_ASSERT_STRING_EQUAL(actual,expected)
 I'm checking to see if others have the same issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3688#comment:6>
