[postgis-tickets] r15483 - Fix buffer overflow and use of uninitialized values
Sandro Santilli
strk at kbt.io
Mon Jul 10 11:00:50 PDT 2017
Author: strk
Date: 2017-07-10 11:00:49 -0700 (Mon, 10 Jul 2017)
New Revision: 15483
branches/2.3/NEWS
branches/2.3/loader/pgsql2shp-core.c
Closes #3101 for 2.3 branch
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2017-07-10 17:51:23 UTC (rev 15482)
+++ branches/2.3/NEWS 2017-07-10 18:00:49 UTC (rev 15483)
@@ -3,12 +3,10 @@
* Bug Fixes
- - #3782, Memory leak in lwline_from_wkb_state
- (Even Rouault)
+ - #3782, Memory leak in lwline_from_wkb_state (Even Rouault)
+ - #3101, Fix buffer overflow in pgsql2shp (Sandro Santilli)
PostGIS 2.3.3
2017/07/01
Modified: branches/2.3/loader/pgsql2shp-core.c
--- branches/2.3/loader/pgsql2shp-core.c 2017-07-10 17:51:23 UTC (rev 15482)
+++ branches/2.3/loader/pgsql2shp-core.c 2017-07-10 18:00:49 UTC (rev 15483)
@@ -1156,6 +1156,7 @@
/* Set any state defaults */
state->conn = NULL;
state->outtype = 's';
+ state->outshptype = 0;
state->geom_oid = 0;
state->geog_oid = 0;
state->schema = NULL;
@@ -1167,6 +1168,7 @@
state->dbffieldtypes = NULL;
state->pgfieldnames = NULL;
state->big_endian = is_bigendian();
+ state->message[0] = '\0';
colmap_init(&state->column_map);
return state;
@@ -1557,9 +1559,13 @@
/* Issue warning if column has been renamed */
if (strcasecmp(dbffieldname, pgfieldname))
+ if ( snprintf(buf, 256, _("Warning, field %s renamed to %s\n"),
+ pgfieldname, dbffieldname) >= 256 )
+ buf[255] = '\0';
/* Note: we concatenate all warnings from the main loop as this is useful information */
- snprintf(buf, 256, _("Warning, field %s renamed to %s\n"), pgfieldname, dbffieldname);
- strncat(state->message, buf, SHPDUMPERMSGLEN - strlen(state->message));
+ strncat(state->message, buf, SHPDUMPERMSGLEN - strlen(state->message) - 1);
ret = SHPDUMPERWARN;
