[postgis-tickets] [PostGIS] #3785: Setup a Bot to run OSS FUZZ tests
PostGIS trac at osgeo.org
Wed Jul 12 22:58:45 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  task       |     Status:  assigned
  Priority:  medium     |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 I was able to get this to run on Debbie with following command (I was
 running under root, I know a no no, but I couldn't access docker from
 postgis-git-sync account I had created earlier.
 Basic steps
 git clone --depth=1 https://github.com/google/oss-fuzz.git oss-fuzz
 cd oss-fuzz
 git pull
 cd projects/postgis
 docker build --no-cache -t postgis-fuzz .
 docker run postgis-fuzz
 I'm not sure how to see fuzz errors though.  Didn't get that far in my
 learning.
 Output shows:
 libtool: link: clang -shared  -fPIC -DPIC  .libs/stringbuffer.o
 .libs/bytebuffer.o .libs/measures.o .libs/measures3d.o .libs/box2d.o
 .libs/ptarray.o .libs/lwgeom_api.o .libs/lwgeom.o .libs/lwpoint.o
 .libs/lwline.o .libs/lwpoly.o .libs/lwtriangle.o .libs/lwmpoint.o
 .libs/lwmline.o .libs/lwmpoly.o .libs/lwboundingcirc
 arreferencing.o .libs/lwprint.o .libs/g_box.o .libs/g_serialized.o
 .libs/g_util.o .libs/lwgeodetic.o .libs/lwgeodetic_tree.o .libs/lwtree.o
 .libs/lwout_gml.o .libs/lwout_kml.o .libs/lwout_geojson.o
 .libs/lwout_svg.o .libs/lwout_x3d.o .libs/lwout_encoded_polyline.o
 .libs/lwgeom_debug.o .libs/lwgeom_geos.o .libs/lwgeo
 libtool: link: (cd ".libs" && rm -f "liblwgeom-2.4.so.0" && ln -s
 "liblwgeom-2.4.so.0.0.0" "liblwgeom-2.4.so.0")
 libtool: link: (cd ".libs" && rm -f "liblwgeom.so" && ln -s
 "liblwgeom-2.4.so.0.0.0" "liblwgeom.so")
 libtool: link: ar cr .libs/liblwgeom.a  stringbuffer.o bytebuffer.o
 measures.o measures3d.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
 lwline.o lwpoly.o lwtriangle.o lwmpoint.o lwmline.o lwmpoly.o
 lwboundingcircle.o lwcollection.o lwcircstring.o lwcompound.o
 lwcurvepoly.o lwmcurve.o lwmsurface.o lwpsurface.o
 luster.o lwgeom_geos_node.o lwgeom_geos_split.o lwgeom_topo.o
 lwgeom_transform.o lwgeom_wrapx.o lwunionfind.o effectivearea.o lwkmeans.o
 kmeans.o varint.o lwspheroid.o
 libtool: link: ranlib .libs/liblwgeom.a
 libtool: link: ( cd ".libs" && rm -f "liblwgeom.la" && ln -s
 "../liblwgeom.la" "liblwgeom.la" )
 + cd ..
 + bash ./fuzzers/build_google_oss_fuzzers.sh
 Building fuzzer wkb_import_fuzzer
 Building fuzzer wkt_import_fuzzer
 + bash ./fuzzers/build_seed_corpus.sh
 I was hoping I could do this on my windows 7 docker install, but sadly I
 got stuck a little stuck:
 I got as far as building the docker image, but when I go to run, the
 output looks like this:
 I had to dos2unix the files cause they came down with windows line breaks,
 but after that got stuck.
 SECURITY WARNING: You are building a Docker image from Windows against a
 non-Win
 dows Docker host. All files and directories added to build context will
 have '-r
 wxr-xr-x' permissions. It is recommended to double check and reset
 permissions f
 or sensitive files and directories.
 dos2unix: converting file project.yaml to Unix format...
 Compiling libFuzzer to /usr/lib/libFuzzingEngine.a ...ar: creating
 /usr/lib/libF
 uzzingEngine.a
  done.
 CC=clang
 CXX=clang++
 CFLAGS=-O1 -fno-omit-frame-pointer -gline-tables-only
 -DFUZZING_BUILD_MODE_UNSAF
 E_FOR_PRODUCTION -fsanitize=address -fsanitize-address-use-after-scope
 -fsanitiz
 e-coverage=trace-pc-guard,trace-cmp
 CXXFLAGS=-O1 -fno-omit-frame-pointer -gline-tables-only
 AFE_FOR_PRODUCTION -fsanitize=address -fsanitize-address-use-after-scope
 -fsanit
 ize-coverage=trace-pc-guard,trace-cmp -stdlib=libc++
 + ./autogen.sh
 * Running /usr/bin/libtoolize (2.4.6)
    OPTIONS = --force --copy --install
 libtoolize: putting auxiliary files in '.'.
 libtoolize: copying file './config.guess'
 libtoolize: copying file './config.sub'
 libtoolize: copying file './install-sh'
 libtoolize: copying file './ltmain.sh'
 libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'macros'.
 libtoolize: copying file 'macros/libtool.m4'
 libtoolize: copying file 'macros/ltoptions.m4'
 libtoolize: copying file 'macros/ltsugar.m4'
 libtoolize: copying file 'macros/ltversion.m4'
 libtoolize: copying file 'macros/lt~obsolete.m4'
 libtoolize: Consider adding '-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
 * Running /usr/bin/aclocal (1.15)
 * Running /usr/bin/autoconf (2.69)
 Now you are ready to run './configure'
 + ./configure --enable-static --without-raster --without-protobuf
 checking build system type... x86_64-pc-linux-gnu
 checking host system type... x86_64-pc-linux-gnu
 checking how to print strings... printf
 checking for gcc... clang
 checking whether the C compiler works... yes
 checking for C compiler default output file name... a.out
 checking for suffix of executables...
 checking whether we are cross compiling... configure: error: in
 `/src/postgis':
 configure: error: cannot run C compiled programs.
 If you meant to cross compile, use `--host'.
 See `config.log' for more details
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3785#comment:2>
