[postgis-tickets] [PostGIS] #3785: Setup a Bot to run OSS FUZZ tests
trac at osgeo.org
Thu Jul 13 00:11:01 PDT 2017
Reporter: robe | Owner: strk
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.4.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Comment (by robe):
duh should have read the instructions. I got it running on my windows box
by changing my command to:
docker run --cap-add SYS_PTRACE -ti postgis-fuzz
So now I get same output as debbie, but I'm lost with docker not sure how
to see outputs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3785#comment:3>
