[postgis-tickets] [PostGIS] #3785: Setup a Bot to run OSS FUZZ tests
PostGIS trac at osgeo.org
Thu Jul 13 03:01:03 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  task       |     Status:  assigned
  Priority:  medium     |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by strk):
 Outputs should be on stdout from docker run.
 Or I think you can add a `--name good-name` switch
 and then `docker logs good-name` to see the output.
 Not passing `--name` assigns a random (but mnemonic) name,
 you can find out the names of runnign dockers via `docker ps`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3785#comment:4>
