[postgis-tickets] [PostGIS] #3786: OSS FUZZ fixes
trac at osgeo.org
Sun Jul 16 22:40:00 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.6
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> I've started an attempt to resolve OSS FUZZ complaints.
> Pull request here, for your input.
> https://git.osgeo.org/gogs/postgis/postgis/pulls/15
> strk doesn't think my change should have made a difference but I tested
> two times. without the change segmentation fault with change no
> segmentation fault.
> My assumption is because the *_cp functions do more checking and internal
> does pretty much none.
> In hind-sight I probably could have achieved the same affect by swapping
> out calls to getPoint2d_internal with getPoint2d_cp without having to
> resort to declaring POINT2D variables.
> I still need to get the extra CPP flags enabled to confirm I got all the
> issues in this bug ticket.
> https://oss-fuzz.com/v2/testcase-detail/4733660446064640?noredirect=1
> Since it complained about others
New description:
segmentation fault.
note based on strk's urging, I switched back to using the earlier
functions, but doing a pointer and npoints check.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3786#comment:7>
