[postgis-tickets] [PostGIS] #3790: "ERROR: could not open extension control file" on BigSQL installation of PostgreSQL
trac at osgeo.org
Mon Jul 17 07:29:25 PDT 2017
PostgreSQL
Reporter: realityexists | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone:
Component: build/upgrade/install | Version: 2.3.x
Resolution: invalid | Keywords:
Comment (by robe):
I had it noted on the download page already. I'll put this paragraph in
bold so it jumps out more.
The installers are designed to work with EDB Application Stackbuilder. If
you are using BigSQL distribution use the PostGIS available via the BigSQL
distribution. If you are on BigSQL (PostgreSQL 9.5+) and need items not
available in BigSQL distribution (e.g. SFCGAL, pgRouting, or development
versions of PostGIS), you can use the binaries in the experimental
section. Note the path you copy to in BigSQL is a little different (e.g.
postgresql/lib instead of lib).
or you thinking the wording of above is not clear enough?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3790#comment:3>
