[postgis-tickets] [PostGIS] #3791: PostGIS tiger geocoder should use cousub in addition to place for non-specific
PostGIS trac at osgeo.org
Mon Jul 17 12:31:45 PDT 2017
specific
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 2.4.0
Component:  tiger geocoder  |    Version:  2.3.x
 Keywords:                  |
 Seems if you do:
   SELECT pprint_addy(addy), ST_AsText(geomout), rating FROM
 geocode('Brooklyn, NY',1);
 you get no answer back although Brooklyn is listed in
 tiger_data.ny_cousub.
 However if you use a value that is in ny_place such as
 geocode('Bronxvilled, NY',1);
 it works.
 tiger should try to use tiger.cousub as well as tiger.place.
 I think cousub might currently only be used for some joins.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3791>
