[postgis-tickets] [PostGIS] #3791: PostGIS tiger geocoder should use cousub in addition to place for non-specific
trac at osgeo.org
Mon Jul 17 23:54:19 PDT 2017
specific
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: tiger geocoder | Version: 2.3.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> Seems if you do:
> SELECT pprint_addy(addy), ST_AsText(geomout), rating FROM
> geocode('Brooklyn, NY',1);
> you get no answer back although Brooklyn is listed in
> tiger_data.ny_cousub.
> However if you use a value that is in ny_place such as
> geocode('Bronxvilled, NY',1);
> it works.
> tiger should try to use tiger.cousub as well as tiger.place.
> I think cousub might currently only be used for some joins.
New description:
Seems if you do:
it works.
this ticket was instigated by this stack exchange post:
https://gis.stackexchange.com/questions/247928/postgis-not-geocoding-
counties
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3791#comment:1>
