[postgis-tickets] r15497 - Schema qualify function calls in postgis_full_version
Regina Obe lr at pcorp.us
Sun Jul 23 01:14:14 PDT 2017
Author: robe
Date: 2017-07-23 01:14:14 -0700 (Sun, 23 Jul 2017)
New Revision: 15497
   trunk/postgis/postgis.sql.in
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2017-07-23 07:02:19 UTC (rev 15496)
+++ trunk/postgis/postgis.sql.in	2017-07-23 08:14:14 UTC (rev 15497)
@@ -2888,22 +2888,22 @@
 	sfcgal_lib_ver text;
 	sfcgal_scr_ver text;
 BEGIN
-	SELECT postgis_lib_version() INTO libver;
-	SELECT postgis_proj_version() INTO projver;
-	SELECT postgis_geos_version() INTO geosver;
-	SELECT postgis_libjson_version() INTO json_lib_ver;
-	SELECT postgis_libprotobuf_version() INTO protobuf_lib_ver;
+	SELECT @extschema at .postgis_lib_version() INTO libver;
+	SELECT @extschema at .postgis_proj_version() INTO projver;
+	SELECT @extschema at .postgis_geos_version() INTO geosver;
+	SELECT @extschema at .postgis_libjson_version() INTO json_lib_ver;
+	SELECT @extschema at .postgis_libprotobuf_version() INTO protobuf_lib_ver;
 	BEGIN
-		SELECT postgis_gdal_version() INTO gdalver;
+		SELECT @extschema at .postgis_gdal_version() INTO gdalver;
 	EXCEPTION
 		WHEN undefined_function THEN
 			gdalver := NULL;
 			RAISE NOTICE 'Function postgis_gdal_version() not found.  Is raster support enabled and rtpostgis.sql installed?';
 	END;
 	BEGIN
-		SELECT postgis_sfcgal_version() INTO sfcgalver;
+		SELECT @extschema at .postgis_sfcgal_version() INTO sfcgalver;
     BEGIN
-      SELECT postgis_sfcgal_scripts_installed() INTO sfcgal_scr_ver;
+      SELECT @extschema at .postgis_sfcgal_scripts_installed() INTO sfcgal_scr_ver;
     EXCEPTION
         sfcgal_scr_ver := 'missing';
@@ -2912,11 +2912,11 @@
 			sfcgalver := NULL;
 	END;
-	SELECT postgis_liblwgeom_version() INTO liblwgeomver;
-	SELECT postgis_libxml_version() INTO libxmlver;
-	SELECT postgis_scripts_installed() INTO dbproc;
-	SELECT postgis_scripts_released() INTO relproc;
-	select postgis_svn_version() INTO svnver;
+	SELECT @extschema at .postgis_liblwgeom_version() INTO liblwgeomver;
+	SELECT @extschema at .postgis_libxml_version() INTO libxmlver;
+	SELECT @extschema at .postgis_scripts_installed() INTO dbproc;
+	SELECT @extschema at .postgis_scripts_released() INTO relproc;
+	select @extschema at .postgis_svn_version() INTO svnver;
 	BEGIN
 		SELECT topology.postgis_topology_scripts_installed() INTO topo_scr_ver;
 	EXCEPTION
@@ -2938,7 +2938,7 @@
 	END;
 	BEGIN
-		SELECT postgis_raster_lib_version() INTO rast_lib_ver;
+		SELECT @extschema at .postgis_raster_lib_version() INTO rast_lib_ver;
 	EXCEPTION
 			rast_lib_ver := NULL;
