[postgis-tickets] [PostGIS] #3796: Git replication appears to be broken
trac at osgeo.org
Thu Jul 27 00:55:07 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
The problem was that the mirroring daemon was killed. Now restarted.
What do you need to finish the setup ?
NOTE: I've tweaked the example CGI script not to hang (although it is via
the hang that i figured the daemon wasn't running..)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3796#comment:4>
