[postgis-tickets] [PostGIS] #3827: Turn off interrupt tests in configure by default until we can make them work consistently
trac at osgeo.org
Sat Sep 2 16:57:26 PDT 2017
work consistently
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Keywords: |
As noted in Greg's extensive packaging notes.
https://lists.osgeo.org/pipermail/postgis-devel/2017-September/026358.html
> I tested on NetBSD 7, amd64, with (because that's what was installed):
> PostgreSQL 9.3.18 on x86_64--netbsd, compiled by gcc (nb2 20150115)
4.8.5, 64-bit
> Postgis 2.4.0beta1 - r15614 - 2017-09-02 16:57:24
> scripts 2.4.0beta1 r15614
> GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
> PROJ: Rel. 4.9.3, 15 August 2016
> and tests passed, modulo two "interrupted late" issues, similar to those
I reported long ago with 2.3.x (and didn't ever pursue hard enough to
fix).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3827>
