[postgis-tickets] [PostGIS] #3828: Warnings during compile on netbsd
PostGIS trac at osgeo.org
Sat Sep 2 17:02:18 PDT 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 This is from Greg Troxel's packaging observations.
 https://lists.osgeo.org/pipermail/postgis-devel/2017-September/026358.html
 Two warnings that I don't remember from before and seem not quite right:
 build:
 gcc -I../../liblwgeom -O2 -D_FORTIFY_SOURCE=2 -I/usr/pkg/include
 -I/usr/include -I/usr/pkg/include/freetype2 -I/usr/include/krb5  -fPIC
 -DPIC  -Wall -Wmissing-prototypes -I/usr/pkg/include  -I/usr/pkg/include
 -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/freetype2
 -I/usr/include/krb5  -c -o rt_raster.o rt_raster.c
 rt_raster.c: In function 'rt_raster_to_gdal_mem':
 rt_raster.c:1966:4: warning: implicit declaration of function 'strnicmp'
 [-Wimplicit-function-declaration]
     if (strnicmp(pszDataPointer, "0x", 2) == 0)
 I think this is #defined to strncasecmp, which needs <strings.h>
 check:
 (I realize this is some kind poor man's polymorphism, but given that
 this is C I would expect some kind of inline function (or maybe a macro)
 to do type-safe casting.  I admit to not reading the make check output
 from earlier versions.)
 gcc -O2 -D_FORTIFY_SOURCE=2 -I/usr/pkg/include -I/usr/include
 -I/usr/pkg/include/freetype2 -I/usr/include/krb5  -Wall -Wmissing-
 prototypes -I/usr/pkg/include  -I/usr/pkg/include -I/usr/include
 -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -I.. -c -o cu_algorithm.o
 cu_algorithm.c
 cu_algorithm.c: In function 'test_lwpoly_construct_circle':
 cu_algorithm.c:1118:2: warning: passing argument 1 of
 'lwgeom_count_vertices' from incompatible pointer type [enabled by
 default]
   ASSERT_INT_EQUAL(lwgeom_count_vertices(p), segments_per_quad * 4 + 1);
 In file included from ../liblwgeom_internal.h:48:0,
                  from cu_algorithm.c:17:
 ../liblwgeom.h:1258:12: note: expected 'const struct LWGEOM *' but
 argument is of type 'struct LWPOLY *'
  extern int lwgeom_count_vertices(const LWGEOM *geom);
 default]
 default]
 cu_algorithm.c:1121:4: warning: assignment discards 'const' qualifier from
 pointer target type [enabled by default]
   g = lwgeom_get_bbox(lwpoly_as_lwgeom(p));
 cu_algorithm.c:1127:2: warning: passing argument 1 of 'lwgeom_area' from
 incompatible pointer type [enabled by default]
   CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(p), M_PI*5*5, 0.1);
 ../liblwgeom.h:1180:15: note: expected 'const struct LWGEOM *' but
  extern double lwgeom_area(const LWGEOM *geom);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3828>
