[postgis-tickets] [PostGIS] #3828: Warnings during compile on netbsd
trac at osgeo.org
Sat Sep 2 17:06:56 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> This is from Greg Troxel's packaging observations.
> https://lists.osgeo.org/pipermail/postgis-
> devel/2017-September/026358.html
> Two warnings that I don't remember from before and seem not quite right:
> build:
> gcc -I../../liblwgeom -O2 -D_FORTIFY_SOURCE=2 -I/usr/pkg/include
> -I/usr/include -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -fPIC
> -DPIC -Wall -Wmissing-prototypes -I/usr/pkg/include -I/usr/pkg/include
> -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/freetype2
> -I/usr/include/krb5 -c -o rt_raster.o rt_raster.c
> rt_raster.c: In function 'rt_raster_to_gdal_mem':
> rt_raster.c:1966:4: warning: implicit declaration of function 'strnicmp'
> [-Wimplicit-function-declaration]
> if (strnicmp(pszDataPointer, "0x", 2) == 0)
> I think this is #defined to strncasecmp, which needs <strings.h>
> check:
> (I realize this is some kind poor man's polymorphism, but given that
> this is C I would expect some kind of inline function (or maybe a macro)
> to do type-safe casting. I admit to not reading the make check output
> from earlier versions.)
> gcc -O2 -D_FORTIFY_SOURCE=2 -I/usr/pkg/include -I/usr/include
> -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -Wall -Wmissing-
> prototypes -I/usr/pkg/include -I/usr/pkg/include -I/usr/include
> -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -I.. -c -o
> cu_algorithm.o cu_algorithm.c
> cu_algorithm.c: In function 'test_lwpoly_construct_circle':
> cu_algorithm.c:1118:2: warning: passing argument 1 of
> 'lwgeom_count_vertices' from incompatible pointer type [enabled by
> default]
> ASSERT_INT_EQUAL(lwgeom_count_vertices(p), segments_per_quad * 4 + 1);
> In file included from ../liblwgeom_internal.h:48:0,
> from cu_algorithm.c:17:
> ../liblwgeom.h:1258:12: note: expected 'const struct LWGEOM *' but
> argument is of type 'struct LWPOLY *'
> extern int lwgeom_count_vertices(const LWGEOM *geom);
> default]
> default]
> cu_algorithm.c:1121:4: warning: assignment discards 'const' qualifier
> from pointer target type [enabled by default]
> g = lwgeom_get_bbox(lwpoly_as_lwgeom(p));
> cu_algorithm.c:1127:2: warning: passing argument 1 of 'lwgeom_area' from
> incompatible pointer type [enabled by default]
> CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(p), M_PI*5*5, 0.1);
> ../liblwgeom.h:1180:15: note: expected 'const struct LWGEOM *' but
> extern double lwgeom_area(const LWGEOM *geom);
New description:
for
PostgreSQL 9.3.18 on x86_64--netbsd, compiled by gcc (nb2 20150115) 4.8.5,
64-bit
Postgis 2.4.0beta1 - r15614 - 2017-09-02 16:57:24
scripts 2.4.0beta1 r15614
GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
PROJ: Rel. 4.9.3, 15 August 2016
https://lists.osgeo.org/pipermail/postgis-devel/2017-September/026358.html
build:
check:
-I/usr/pkg/include/freetype2 -I/usr/include/krb5 -I.. -c -o cu_algorithm.o
cu_algorithm.c
default]
default]
default]
cu_algorithm.c:1121:4: warning: assignment discards 'const' qualifier from
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3828#comment:2>
