[postgis-tickets] [PostGIS] #3723: st_geohash not correct for some multipoint
PostGIS trac at osgeo.org
Fri Sep 8 06:04:56 PDT 2017
  Reporter:  hzhang   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.2.x
Resolution:  fixed    |   Keywords:  st_geohash
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Interesting. Geohash is really annoying in that each char carries 5 bits
 of information, so not a complete cycle of x/y adjustments of the bounds
 in the algorithm. The issue was that one calculation was returning only a
 complete cycle of info (the precision calc) while the other was returning
 the partial cycles (the bounds calc). It seems that adjusting the
 precision calc to do partials makes things better without making things
 worse, so I've done that.
 Trunk at r15661
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3723#comment:5>
