[postgis-tickets] [PostGIS] #3837: --enable-debug to set PARANOIA level
PostGIS trac at osgeo.org
Fri Sep 8 09:28:53 PDT 2017
 Reporter:  pramsey      |      Owner:  pramsey
     Type:  enhancement  |     Status:  assigned
 Priority:  critical     |  Milestone:  PostGIS 2.4.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 Repurpose the --enable-debug flag to turn on PARANOIA and add as much -g
 debugging as possible (in particular to liblwgeom, since ./postgis
 inherits its flags from the pgsql build in pg_config --cflags)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3837>
