[postgis-tickets] [PostGIS] #3837: --enable-debug to set	PARANOIA level
    trac at osgeo.org
    Fri Sep  8 12:25:08 PDT 2017
  Reporter:  pramsey      |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  critical     |  Milestone:  PostGIS 2.4.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Comment (by robe):
 note sure if related to this but dronie seems not happy.  Was happy commit
 before
 https://drone.osgeo.org/postgis/postgis/274
 #3837, --enable-debug to set PARANOIA level This required some re-working
 of the protobuf sections, for reasons that aren't clear. However,
 hopefully that re-working will also fix things for others. Basically, the
 pkg-config portions seemed to only work by accident for the folks who
 wrote them initially, so they are improved, and the use of --without is
 more strongly enforced in the conditional blocks git-svn-id:
 http://svn.osgeo.org/postgis/trunk@15662 b70326c6-7e19-0410-871a-
 916f4a2858ee
   Test: test_lw_arc_center ...passed
   Test: test_point_density ...passed
   Test: test_kmeans ...passed
   Test: test_median_handles_3d_correctly ...passed
   Test: test_median_robustness ...make[2]: Leaving directory
 `/drone/src/git.osgeo.org/gogs/postgis/postgis/liblwgeom/cunit'
 make[2]: *** [check] Segmentation fault (core dumped)
 make[1]: Leaving directory
 `/drone/src/git.osgeo.org/gogs/postgis/postgis/liblwgeom'
 make[1]: *** [check] Error 2
 make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3837#comment:2>
