[postgis-tickets] [PostGIS] #3837: --enable-debug to set PARANOIA level
trac at osgeo.org
Fri Sep 8 12:28:24 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: reopened
Priority: critical | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
reopening debbie has also voiced her disapproval.
https://debbie.postgis.net/job/PostGIS_Regress/6497/consoleFull
-------------- Compiler Info -------------
C compiler: gcc -g -O2
SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-------------- Dependencies --------------
GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.7.0devw64/bin/geos-config
GEOS version: 3.7.0dev
GDAL config: /var/lib/jenkins/workspace/gdal/rel-2.2w64/bin
/gdal-config
GDAL version: 2.2.1
SFCGAL config: /usr/bin/sfcgal-config
SFCGAL version: 1.3.0
PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg9.6w64/bin/pg_config
PostgreSQL version: PostgreSQL 9.6.5
PROJ4 version: 49
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.4
JSON-C support: yes
protobuf-c support: yes
PCRE support: yes
PostGIS debug level:
Perl: /usr/bin/perl
Suite: computational_geometry
Test: test_lw_segment_side ...passed
Test: test_lw_segment_intersects ...passed
Test: test_lwline_crossing_short_lines ...passed
Test: test_lwline_crossing_long_lines ...passed
Test: test_lwline_crossing_bugs ...passed
Test: test_lwpoint_set_ordinate ...passed
Test: test_lwpoint_get_ordinate ...passed
Test: test_point_interpolate ...passed
Test: test_lwline_clip ...passed
Test: test_lwline_clip_big ...passed
Test: test_lwmline_clip ...passed
Test: test_geohash_point ...passed
Test: test_geohash_precision ...passed
Test: test_geohash ...passed
Test: test_geohash_point_as_int ...passed
Test: test_isclosed ...passed
Test: test_lwgeom_simplify ...passed
Test: test_lw_arc_center ...passed
Test: test_point_density ...passed
Test: test_kmeans ...passed
Test: test_median_handles_3d_correctly ...passed
Test: test_median_robustness ...Makefile:86: recipe for target 'check'
failed
make[2]: *** [check] Segmentation fault
make[2]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.4/liblwgeom/cunit'
Makefile:205: recipe for target 'check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.4/liblwgeom'
GNUmakefile:16: recipe for target 'check' failed
make: *** [check] Error 1
Build step 'Execute shell' marked build as failure
An attempt to send an e-mail to empty list of recipients, ignored.
Warning: you have no plugins providing access control for builds, so
falling back to legacy behavior of permitting any downstream builds to be
triggered
Triggering a new build of PostgreSQL stop
Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3837#comment:3>
