[postgis-tickets] r15665 - ST_AsMVT/ST_AsMVTGeom/ST_AsGeobuf final signature revision
bjorn at wololo.org
bjorn at wololo.org
Fri Sep 8 13:25:28 PDT 2017
Author: bjornharrtell
Date: 2017-09-08 13:25:28 -0700 (Fri, 08 Sep 2017)
New Revision: 15665
trunk/doc/reference_output.xml
trunk/postgis/geobuf.c
trunk/postgis/geobuf.h
trunk/postgis/lwgeom_out_geobuf.c
trunk/postgis/lwgeom_out_mvt.c
trunk/postgis/mvt.c
trunk/postgis/mvt.h
trunk/postgis/postgis.sql.in
trunk/postgis/postgis_drop_before.sql
trunk/regress/geobuf.sql
trunk/regress/geobuf_expected
trunk/regress/mvt.sql
trunk/regress/mvt_expected
trunk/regress/mvt_jsonb.sql
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/doc/reference_output.xml 2017-09-08 20:25:28 UTC (rev 15665)
@@ -1308,10 +1308,14 @@
</refnamediv>
<refsynopsisdiv>
<funcsynopsis>
+ <funcprototype>
+ <funcdef>bytea <function>ST_AsGeobuf</function></funcdef>
+ <paramdef><type>anyelement set </type> <parameter>row</parameter></paramdef>
+ </funcprototype>
<funcprototype>
+ <paramdef><type>anyelement </type> <parameter>row</parameter></paramdef>
<paramdef><type>text </type> <parameter>geom_name</parameter></paramdef>
- <paramdef><type>anyelement </type> <parameter>row</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
@@ -1325,7 +1329,7 @@
Note that Geobuf in its current form cannot be streamed so the full output will be assembled in memory.
</para>
- <para><varname>geom_name</varname> is the name of the geometry column in the row data.</para>
+ <para><varname>geom_name</varname> is the name of the geometry column in the row data. If NULL it will default to the first found geometry column.</para>
<para><varname>row</varname> row data with at least a geometry column.</para>
<para>Availability: 2.4.0</para>
@@ -1356,9 +1360,9 @@
<funcdef>geometry <function>ST_AsMVTGeom</function></funcdef>
<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
<paramdef><type>box2d </type> <parameter>bounds</parameter></paramdef>
- <paramdef><type>int4 </type> <parameter>extent</parameter></paramdef>
- <paramdef><type>int4 </type> <parameter>buffer</parameter></paramdef>
- <paramdef><type>bool </type> <parameter>clip_geom</parameter></paramdef>
+ <paramdef choice="opt"><type>int4 </type> <parameter>extent=4096</parameter></paramdef>
+ <paramdef choice="opt"><type>int4 </type> <parameter>buffer=0</parameter></paramdef>
+ <paramdef choice="opt"><type>bool </type> <parameter>clip_geom=true</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
@@ -1402,12 +1406,27 @@
</refnamediv>
<refsynopsisdiv>
<funcsynopsis>
+ <funcprototype>
+ <funcdef>bytea <function>ST_AsMVT</function></funcdef>
+ </funcprototype>
<funcprototype>
<paramdef><type>text </type> <parameter>name</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>text </type> <parameter>name</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>int4 </type> <parameter>extent</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
@@ -1427,10 +1446,10 @@
deep. The keys and values in the object will be parsed into feature attributes.
</para>
- <para><varname>name</varname> is the name of the Layer</para>
+ <para><varname>row</varname> row data with at least a geometry column.</para>
+ <para><varname>name</varname> is the name of the Layer. If NULL it will use the string "default".</para>
<para><varname>extent</varname> is the tile extent in screen space as defined by the specification. If NULL it will default to 4096.</para>
- <para><varname>row</varname> row data with at least a geometry column.</para>
</refsection>
Modified: trunk/postgis/geobuf.c
--- trunk/postgis/geobuf.c 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/geobuf.c 2017-09-08 20:25:28 UTC (rev 15665)
@@ -55,24 +55,34 @@
int natts = tupdesc->natts;
char **keys = palloc(natts * sizeof(*keys));
uint32_t i, k = 0;
- bool geom_name_found = false;
+ bool geom_found = false;
for (i = 0; i < natts; i++) {
#if POSTGIS_PGSQL_VERSION < 110
+ Oid typoid = getBaseType(tupdesc->attrs[i]->atttypid);
char *tkey = tupdesc->attrs[i]->attname.data;
#else
+ Oid typoid = getBaseType(tupdesc->attrs[i].atttypid);
char *tkey = tupdesc->attrs[i].attname.data;
#endif
char *key = palloc(strlen(tkey) + 1);
strcpy(key, tkey);
- if (strcmp(key, ctx->geom_name) == 0) {
- ctx->geom_index = i;
- geom_name_found = true;
- continue;
+ if (ctx->geom_name == NULL) {
+ if (!geom_found && typoid == TypenameGetTypid("geometry")) {
+ ctx->geom_index = i;
+ geom_found = 1;
+ continue;
+ } else {
+ if (!geom_found && strcmp(key, ctx->geom_name) == 0) {
+ geom_found = 1;
+ continue;
keys[k++] = key;
- if (!geom_name_found)
- elog(ERROR, "encode_keys: no column with specificed geom_name found");
+ if (!geom_found)
+ elog(ERROR, "encode_keys: no geometry column found");
ctx->data->n_keys = k;
ctx->data->keys = keys;
ReleaseTupleDesc(tupdesc);
@@ -617,8 +627,7 @@
for (i = 0; i < fc->n_features; i++)
- fc->features[i]->geometry = encode_geometry(ctx,
- ctx->lwgeoms[i]);
+ fc->features[i]->geometry = encode_geometry(ctx, ctx->lwgeoms[i]);
size_t len = data__get_packed_size(data);
uint8_t *buf = palloc(sizeof(*buf) * (len + VARHDRSZ));
Modified: trunk/postgis/geobuf.h
--- trunk/postgis/geobuf.h 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/geobuf.h 2017-09-08 20:25:28 UTC (rev 15665)
@@ -31,7 +31,8 @@
#include "utils/array.h"
#include "utils/typcache.h"
#include "utils/lsyscache.h"
-#include "catalog/pg_type.h"
+#include "catalog/pg_type.h"
+#include "catalog/namespace.h"
#include "executor/spi.h"
#include "executor/executor.h"
#include "access/htup_details.h"
Modified: trunk/postgis/lwgeom_out_geobuf.c
--- trunk/postgis/lwgeom_out_geobuf.c 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/lwgeom_out_geobuf.c 2017-09-08 20:25:28 UTC (rev 15665)
@@ -58,17 +58,18 @@
if (PG_ARGISNULL(0)) {
ctx = palloc(sizeof(*ctx));
- if (PG_ARGISNULL(1))
- elog(ERROR, "pgis_asgeobuf_transfn: parameter geom_name cannot be null");
- ctx->geom_name = text_to_cstring(PG_GETARG_TEXT_P(1));
+ ctx->geom_name = NULL;
+ if (PG_NARGS() > 2 && !PG_ARGISNULL(2))
+ ctx->geom_name = text_to_cstring(PG_GETARG_TEXT_P(2));
geobuf_agg_init_context(ctx);
} else {
ctx = (struct geobuf_agg_context *) PG_GETARG_POINTER(0);
- if (!type_is_rowtype(get_fn_expr_argtype(fcinfo->flinfo, 2)))
+ if (!type_is_rowtype(get_fn_expr_argtype(fcinfo->flinfo, 1)))
elog(ERROR, "pgis_asgeobuf_transfn: parameter row cannot be other than a rowtype");
- ctx->row = PG_GETARG_HEAPTUPLEHEADER(2);
+ ctx->row = PG_GETARG_HEAPTUPLEHEADER(1);
geobuf_agg_transfn(ctx);
PG_RETURN_POINTER(ctx);
Modified: trunk/postgis/lwgeom_out_mvt.c
--- trunk/postgis/lwgeom_out_mvt.c 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/lwgeom_out_mvt.c 2017-09-08 20:25:28 UTC (rev 15665)
@@ -90,28 +90,26 @@
- elog(ERROR, "pgis_asmvt_transfn: parameter name cannot be null");
- text *name = PG_GETARG_TEXT_P(1);
- ctx->name = text_to_cstring(name);
- PG_FREE_IF_COPY(name, 1);
- ctx->extent = PG_ARGISNULL(2) ? 4096 : PG_GETARG_INT32(2);
- if (PG_ARGISNULL(3))
- elog(ERROR, "pgis_asmvt_transfn: parameter geom_name cannot be null");
- text *geom_name = PG_GETARG_TEXT_P(3);
- ctx->geom_name = text_to_cstring(geom_name);
- PG_FREE_IF_COPY(geom_name, 3);
+ ctx->name = "default";
+ ctx->name = text_to_cstring(PG_GETARG_TEXT_P(2));
+ ctx->extent = 4096;
+ if (PG_NARGS() > 3 && !PG_ARGISNULL(3))
+ ctx->extent = PG_GETARG_INT32(3);
+ if (PG_NARGS() > 4 && !PG_ARGISNULL(4))
+ ctx->geom_name = text_to_cstring(PG_GETARG_TEXT_P(4));
mvt_agg_init_context(ctx);
} else {
ctx = (struct mvt_agg_context *) PG_GETARG_POINTER(0);
- if (!type_is_rowtype(get_fn_expr_argtype(fcinfo->flinfo, 4)))
elog(ERROR, "pgis_asmvt_transfn: parameter row cannot be other than a rowtype");
- ctx->row = PG_GETARG_HEAPTUPLEHEADER(4);
mvt_agg_transfn(ctx);
- PG_FREE_IF_COPY(ctx->row, 4);
+ PG_FREE_IF_COPY(ctx->row, 1);
#endif
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/mvt.c 2017-09-08 20:25:28 UTC (rev 15665)
@@ -301,10 +301,10 @@
TupleDesc tupdesc = get_tuple_desc(ctx);
uint32_t i;
POSTGIS_DEBUG(2, "parse_column_keys called");
-#if POSTGIS_PGSQL_VERSION < 110
+#if POSTGIS_PGSQL_VERSION < 110
#else
@@ -317,32 +317,41 @@
#endif
strcpy(key, tkey);
- geom_name_found = 1;
- continue;
+ geom_found = 1;
+ continue;
+ } else {
+ geom_found = 1;
+ continue;
add_key(ctx, key);
- elog(ERROR, "parse_column_keys: no column '%s' found", ctx->geom_name);
+ if (!geom_found)
+ elog(ERROR, "parse_column_keys: no geometry column found");
-static void encode_keys(struct mvt_agg_context *ctx) {
+static void encode_keys(struct mvt_agg_context *ctx)
struct mvt_kv_key *kv;
size_t n_keys = ctx->keys_hash_i;
char **keys = palloc(n_keys * sizeof(*keys));
- for (kv = ctx->keys_hash; kv != NULL; kv=kv->hh.next) {
+ for (kv = ctx->keys_hash; kv != NULL; kv=kv->hh.next)
keys[kv->id] = kv->name;
ctx->layer->n_keys = n_keys;
ctx->layer->keys = keys;
HASH_CLEAR(hh, ctx->keys_hash);
-static VectorTile__Tile__Value *create_value() {
+static VectorTile__Tile__Value *create_value()
VectorTile__Tile__Value *value = palloc(sizeof(*value));
vector_tile__tile__value__init(value);
return value;
@@ -560,7 +569,7 @@
if (i == ctx->geom_index)
continue;
#else
Modified: trunk/postgis/mvt.h
--- trunk/postgis/mvt.h 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/mvt.h 2017-09-08 20:25:28 UTC (rev 15665)
@@ -32,6 +32,7 @@
#include "access/htup.h"
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/postgis.sql.in 2017-09-08 20:25:28 UTC (rev 15665)
@@ -4368,19 +4368,37 @@
-- Availability: 2.4.0
-CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, text, int4, text, anyelement)
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement)
RETURNS internal
AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
LANGUAGE c IMMUTABLE _PARALLEL;
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text)
+ RETURNS internal
+ AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
+ LANGUAGE c IMMUTABLE _PARALLEL;
+-- Availability: 2.4.0
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4)
+ RETURNS internal
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4, text)
+ RETURNS internal
CREATE OR REPLACE FUNCTION pgis_asmvt_finalfn(internal)
RETURNS bytea
AS 'MODULE_PATHNAME', 'pgis_asmvt_finalfn'
-CREATE AGGREGATE ST_AsMVT(text, int4, text, anyelement)
+CREATE AGGREGATE ST_AsMVT(anyelement)
sfunc = pgis_asmvt_transfn,
stype = internal,
@@ -4391,7 +4409,40 @@
-CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent int4, buffer int4, clip_geom bool)
+CREATE AGGREGATE ST_AsMVT(anyelement, text)
+ sfunc = pgis_asmvt_transfn,
+ stype = internal,
+#if POSTGIS_PGSQL_VERSION >= 96
+ parallel = safe,
+#endif
+ finalfunc = pgis_asmvt_finalfn
+CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
+ stype = internal,
+ parallel = safe,
+#endif
+CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
+ stype = internal,
+ parallel = safe,
+#endif
+CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent int4 default 4096, buffer int4 default 0, clip_geom bool default true)
RETURNS geometry
AS 'MODULE_PATHNAME','ST_AsMVTGeom'
LANGUAGE 'c' IMMUTABLE _PARALLEL;
@@ -4409,19 +4460,25 @@
-CREATE OR REPLACE FUNCTION pgis_asgeobuf_transfn(internal, text, anyelement)
+CREATE OR REPLACE FUNCTION pgis_asgeobuf_transfn(internal, anyelement)
RETURNS internal
AS 'MODULE_PATHNAME', 'pgis_asgeobuf_transfn'
+CREATE OR REPLACE FUNCTION pgis_asgeobuf_transfn(internal, anyelement, text)
+ RETURNS internal
+ AS 'MODULE_PATHNAME', 'pgis_asgeobuf_transfn'
CREATE OR REPLACE FUNCTION pgis_asgeobuf_finalfn(internal)
RETURNS bytea
AS 'MODULE_PATHNAME', 'pgis_asgeobuf_finalfn'
-CREATE AGGREGATE ST_AsGeobuf(text, anyelement)
+CREATE AGGREGATE ST_AsGeobuf(anyelement)
sfunc = pgis_asgeobuf_transfn,
stype = internal,
@@ -4431,7 +4488,18 @@
finalfunc = pgis_asgeobuf_finalfn
+CREATE AGGREGATE ST_AsGeobuf(anyelement, text)
+ sfunc = pgis_asgeobuf_transfn,
+ stype = internal,
+ parallel = safe,
+#endif
+ finalfunc = pgis_asgeobuf_finalfn
-- GeoHash (geohash.org)
Modified: trunk/postgis/postgis_drop_before.sql
--- trunk/postgis/postgis_drop_before.sql 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/postgis/postgis_drop_before.sql 2017-09-08 20:25:28 UTC (rev 15665)
@@ -50,7 +50,7 @@
DROP FUNCTION IF EXISTS gserialized_gist_sel_nd(internal, oid, internal, int4) ;
ALTER FUNCTION geography_gist_selectivity(internal, oid, internal, int4) RENAME TO gserialized_gist_sel_nd;
END IF;
IF EXISTS(SELECT oprname from pg_operator where oprname = '&&' AND oprjoin::text = 'geography_gist_join_selectivity') THEN
--it is bound to old name, drop new, rename old to new, install will fix body of code
DROP FUNCTION IF EXISTS gserialized_gist_joinsel_nd(internal, oid, internal, smallint) ;
@@ -67,4 +67,11 @@
DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4,int8);
DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4,int8,boolean);
+-- Old signatures for protobuf related functions improved in 2.4.0 RC/final
+DROP AGGREGATE IF EXISTS ST_AsMVT(text, int4, text, anyelement);
+DROP FUNCTION IF EXISTS ST_AsMVTGeom(geom geometry, bounds box2d, extent int4, buffer int4, clip_geom bool);
+DROP AGGREGATE IF EXISTS ST_AsGeobuf(text, anyelement);
+DROP FUNCTION IF EXISTS pgis_asgeobuf_transfn(internal, text, anyelement);
+DROP FUNCTION IF EXISTS pgis_asmvt_transfn(internal, text, int4, text, anyelement);
DROP VIEW IF EXISTS geometry_columns; -- removed cast 2.2.0 so need to recreate
Modified: trunk/regress/geobuf.sql
--- trunk/regress/geobuf.sql 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/regress/geobuf.sql 2017-09-08 20:25:28 UTC (rev 15665)
@@ -1,19 +1,21 @@
--set client_min_messages to DEBUG3;
-SELECT 'T1', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T1', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_MakePoint(1.1, 2.1) AS geom) AS q;
-SELECT 'T2', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T2', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT 'test' as test_str, 1 as test_pos_int, -1 as test_neg_int, 1.1 as test_numeric, 1.1::float as test_float, ST_MakeLine(ST_MakePoint(1,1), ST_MakePoint(2,2)) as geom) AS q;
-SELECT 'T3', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T3', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_GeomFromText('POLYGON((0 0,0 1,1 1,1 0,0 0))') as geom) AS q;
-SELECT 'T4', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T4', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_GeomFromText('POLYGON((0 0,0 5,5 5,5 0,0 0), (1 1,1 2,2 2,2 1,1 1))') as geom) AS q;
-SELECT 'T5', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T5', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_GeomFromText('MULTIPOINT (10 40, 40 30, 20 20, 30 10)') as geom) AS q;
-SELECT 'T6', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T6', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_GeomFromText('MULTILINESTRING ((10 10, 20 20, 10 40), (40 40, 30 30, 40 20, 30 10))') as geom) AS q;
-SELECT 'T7', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T7', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_GeomFromText('MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))') as geom) AS q;
-SELECT 'T8', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T8', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_GeomFromText('GEOMETRYCOLLECTION(POINT(4 6),LINESTRING(4 6,7 10))') as geom) AS q;
-SELECT 'T9', encode(ST_AsGeobuf('geom', q), 'base64')
+SELECT 'T9', encode(ST_AsGeobuf(q, 'geom'), 'base64')
FROM (SELECT ST_MakePoint(1, 2, 3) as geom) AS q;
+SELECT 'T10', encode(ST_AsGeobuf(q), 'base64')
+ FROM (SELECT ST_MakePoint(1, 2, 3) as geom) AS q;
Modified: trunk/regress/geobuf_expected
--- trunk/regress/geobuf_expected 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/regress/geobuf_expected 2017-09-08 20:25:28 UTC (rev 15665)
@@ -9,3 +9,4 @@
T7|GAAiJgokCiIIBRIGAgEDAgUDGhZQUCcKMh0oRhMJACcoCR4ePCgTCQAU
T8|GAAiGAoWChQIBiIGCAAaAggMIggIAhoECAwGCA==
T9|EAMYACILCgkKBwgAGgMCBAY=
+T10|EAMYACILCgkKBwgAGgMCBAY=
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/regress/mvt.sql 2017-09-08 20:25:28 UTC (rev 15665)
@@ -41,57 +41,57 @@
4096, 0, true)));
-- geometry encoding tests
-SELECT 'TG1', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom) AS q;
-SELECT 'TG2', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG2', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, 26 18)'),
-SELECT 'TG3', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG3', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 1000 1000)'),
-SELECT 'TG4', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG4', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 500 500, 1000 1000)'),
-SELECT 'TG5', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG5', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTILINESTRING((1 1, 501 501, 1001 1001),(2 2, 502 502, 1002 1002))'),
-SELECT 'TG6', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG6', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'),
-SELECT 'TG7', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG7', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))'),
-SELECT 'TG8', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG8', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-SELECT 'TG9', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
+SELECT 'TG9', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, -26 -18)'),
-- attribute encoding tests
-SELECT 'TA1', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
+SELECT 'TA1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
-SELECT 'TA2', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1.1::double precision AS c1,
+SELECT 'TA2', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1.1::double precision AS c1,
-SELECT 'TA3', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT NULL::integer AS c1,
+SELECT 'TA3', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT NULL::integer AS c1,
-SELECT 'TA4', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (
+SELECT 'TA4', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (
SELECT 1 AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
UNION
SELECT 2 AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
-SELECT 'TA5', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT
+SELECT 'TA5', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom, 1 AS c1, 'abcd'::text AS c2) AS q;
-SELECT 'TA6', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1, -1 AS c2,
+SELECT 'TA6', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, -1 AS c2,
-SELECT 'TA7', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (
+SELECT 'TA7', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (
SELECT 'test' AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
UNION
@@ -100,7 +100,7 @@
UNION
SELECT 'othertest' AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
-SELECT 'TA8', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (
+SELECT 'TA8', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (
SELECT 1::int AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
UNION
@@ -110,9 +110,34 @@
SELECT 2::int AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+-- default values tests
+SELECT 'D1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+ ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom) AS q;
+SELECT 'D2', encode(ST_AsMVT(q, 'test', 4096), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
+SELECT 'D3', encode(ST_AsMVT(q, 'test'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
+SELECT 'D4', encode(ST_AsMVT(q), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
+select 'D5', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+ ST_Point(1, 2),
+ 4096, 0)));
+select 'D6', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+ ST_Point(1, 2),
+ 4096)));
+select 'D7', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+ ST_Point(1, 2),
+ ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)))));
-- unsupported input
SELECT 'TU2';
-SELECT encode(ST_AsMVT('test', 4096, 'geom', 1), 'base64');
+SELECT encode(ST_AsMVT(1, 'test', 4096, 'geom'), 'base64');
SELECT 'TU3';
-SELECT encode(ST_AsMVT('test', 4096, 'geom', q), 'base64')
+SELECT encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64')
FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
Modified: trunk/regress/mvt_expected
--- trunk/regress/mvt_expected 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/regress/mvt_expected 2017-09-08 20:25:28 UTC (rev 15665)
@@ -28,6 +28,13 @@
CW90aGVydGVzdCIGCgR0ZXN0KIAgeAI=
TA8|GkEKBHRlc3QSDBICAAAYASIECTLePxIMEgIAABgBIgQJNNw/EgwSAgABGAEiBAk03D8aAmMxIgIo
ASICKAIogCB4Ag==
+D1|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
+D2|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
+D3|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
+D4|GjIKB2RlZmF1bHQSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
+D5|POINT(1 4094)
+D6|POINT(1 4094)
+D7|POINT(1 4094)
TU2
ERROR: pgis_asmvt_transfn: parameter row cannot be other than a rowtype
TU3
Modified: trunk/regress/mvt_jsonb.sql
--- trunk/regress/mvt_jsonb.sql 2017-09-08 20:09:11 UTC (rev 15664)
+++ trunk/regress/mvt_jsonb.sql 2017-09-08 20:25:28 UTC (rev 15665)
@@ -1,6 +1,6 @@
-SELECT 'TA9', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT '{"c1":1,"c2":"abcd"}'::jsonb,
+SELECT 'TA9', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT '{"c1":1,"c2":"abcd"}'::jsonb,
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom) AS q;
-SELECT 'TA10', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT '{"c1":"abcd", "c2":"abcd"}'::jsonb,
+SELECT 'TA10', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT '{"c1":"abcd", "c2":"abcd"}'::jsonb,
