[postgis-tickets] r15666 - Fix commenting of anyelement aggregates (will make more generic at a later time).
Regina Obe lr at pcorp.us
Fri Sep 8 13:48:38 PDT 2017
Author: robe
Date: 2017-09-08 13:48:38 -0700 (Fri, 08 Sep 2017)
New Revision: 15666
   trunk/doc/xsl/postgis_comments.sql.xsl
Modified: trunk/doc/xsl/postgis_comments.sql.xsl
--- trunk/doc/xsl/postgis_comments.sql.xsl	2017-09-08 20:25:28 UTC (rev 15665)
+++ trunk/doc/xsl/postgis_comments.sql.xsl	2017-09-08 20:48:38 UTC (rev 15666)
@@ -1,92 +1,93 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
-	 Copyright 2008, Regina Obe
-     License: BSD
-	 Purpose: This is an xsl transform that generates PostgreSQL COMMENT ON FUNCTION ddl
-	 statements from postgis xml doc reference
-	<xsl:output method="text" />
-	<!-- We deal only with the reference chapter -->
-        <xsl:template match="/">
-                <xsl:apply-templates select="/book/chapter[@id='reference']" />
-        </xsl:template>
-        <xsl:template match="chapter">
-		<xsl:variable name="ap"><xsl:text>'</xsl:text></xsl:variable>
-<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
-		<xsl:for-each select="sect1[not(contains(@id,'Operator') or contains(@id,'sfcgal') or contains(@id,'GUC') )]/refentry">
-		  <xsl:variable name='plaincomment'>
-		  	<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
-		  </xsl:variable>
-<!-- Replace apostrophes with 2 apostrophes needed for escaping in SQL -->
-		<xsl:variable name='comment'>
-			<xsl:call-template name="globalReplace">
-				<xsl:with-param name="outputString" select="$plaincomment"/>
-				<xsl:with-param name="target" select="$ap"/>
-				<xsl:with-param name="replacement" select="''"/>
-			</xsl:call-template>
-		</xsl:variable>
-		<xsl:choose>
-<!-- If this is a postgis type grab the ref entry summary and refname to make type comment -->
-<xsl:when test="parent::sect1[@id='PostGIS_Types'] and not(contains(refnamediv/refname, 'raster') or contains(refnamediv/refname, 'geomval'))">
-	COMMENT ON TYPE <xsl:value-of select="refnamediv/refname" /> IS 'postgis type: <xsl:value-of select='$comment' />';
-</xsl:when>
-		</xsl:choose>
-<!-- For each function prototype generate the DDL comment statement
-	If its input is a geometry set - we know it is an aggregate function rather than a regular function
-	If its input is a geometry winset we know it is a window function but comment signature of those are the same just have to strip off the winset
-	Do not output OUT params since they define output rather than act as input and do not put a comma after argument just before an OUT parameter -->
-		<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
-COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,'geometry set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
-<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:when test="contains(type,'geometry winset')">geometry</xsl:when><xsl:when test="contains(type,'geography winset')">geography</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
-</xsl:choose></xsl:for-each>) IS '<xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template> <xsl:value-of select='$comment' />';
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-<!--General replace macro hack to make up for the fact xsl 1.0 does not have a built in one.
-	Not needed for xsl 2.0 lifted from http://www.xml.com/pub/a/2002/06/05/transforming.html -->
-	<xsl:template name="globalReplace">
-	  <xsl:param name="outputString"/>
-	  <xsl:param name="target"/>
-	  <xsl:param name="replacement"/>
-	  <xsl:choose>
-		<xsl:when test="contains($outputString,$target)">
-			"concat(substring-before($outputString,$target),
-				   $replacement)"/>
-				 select="substring-after($outputString,$target)"/>
-			<xsl:with-param name="target" select="$target"/>
-				 select="$replacement"/>
-		</xsl:when>
-		<xsl:otherwise>
-		  <xsl:value-of select="$outputString"/>
-		</xsl:otherwise>
-	  </xsl:choose>
-	</xsl:template>
-	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function.  -->
-	<xsl:template name="listparams">
-		<xsl:param name="func" />
-		<xsl:for-each select="$func">
-			<xsl:if test="count(paramdef/parameter) > 0">args: </xsl:if>
-			<xsl:for-each select="paramdef">
-				<xsl:choose>
-					<xsl:when test="count(parameter) > 0">
-						<xsl:value-of select="parameter" />
-					</xsl:when>
-				</xsl:choose>
-				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
-			</xsl:for-each>
-			<xsl:if test="count(paramdef/parameter) > 0"> - </xsl:if>
-		</xsl:for-each>
-	</xsl:template>
-</xsl:stylesheet>
+<?xml version="1.0" encoding="UTF-8"?>
+<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+	 Copyright 2008, Regina Obe
+     License: BSD
+	 Purpose: This is an xsl transform that generates PostgreSQL COMMENT ON FUNCTION ddl
+	 statements from postgis xml doc reference
+	<xsl:output method="text" />
+	<!-- We deal only with the reference chapter -->
+        <xsl:template match="/">
+                <xsl:apply-templates select="/book/chapter[@id='reference']" />
+        </xsl:template>
+        <xsl:template match="chapter">
+		<xsl:variable name="ap"><xsl:text>'</xsl:text></xsl:variable>
+<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+		<xsl:for-each select="sect1[not(contains(@id,'Operator') or contains(@id,'sfcgal') or contains(@id,'GUC') )]/refentry">
+		  <xsl:variable name='plaincomment'>
+		  	<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+		  </xsl:variable>
+<!-- Replace apostrophes with 2 apostrophes needed for escaping in SQL -->
+		<xsl:variable name='comment'>
+			<xsl:call-template name="globalReplace">
+				<xsl:with-param name="outputString" select="$plaincomment"/>
+				<xsl:with-param name="target" select="$ap"/>
+				<xsl:with-param name="replacement" select="''"/>
+			</xsl:call-template>
+		</xsl:variable>
+		<xsl:choose>
+<!-- If this is a postgis type grab the ref entry summary and refname to make type comment -->
+<xsl:when test="parent::sect1[@id='PostGIS_Types'] and not(contains(refnamediv/refname, 'raster') or contains(refnamediv/refname, 'geomval'))">
+	COMMENT ON TYPE <xsl:value-of select="refnamediv/refname" /> IS 'postgis type: <xsl:value-of select='$comment' />';
+</xsl:when>
+		</xsl:choose>
+<!-- For each function prototype generate the DDL comment statement
+	If its input has the word set we no it is an aggregate
+	If its input has the word winset we know it is a window function but comment signature of those are the same just have to strip off the winset
+	Do not output OUT params since they define output rather than act as input and do not put a comma after argument just before an OUT parameter
+	TODO:  revise case to handle any set, winset data type (right now hardcoded geometry, any element-->
+		<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
+COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,' set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
+<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'anyelement set')">anyelement</xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:when test="contains(type,'anyelement winset')">anyelement</xsl:when><xsl:when test="contains(type,'geometry winset')">geometry</xsl:when><xsl:when test="contains(type,'geography winset')">geography</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
+</xsl:choose></xsl:for-each>) IS '<xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template> <xsl:value-of select='$comment' />';
+			</xsl:for-each>
+		</xsl:for-each>
+	</xsl:template>
+<!--General replace macro hack to make up for the fact xsl 1.0 does not have a built in one.
+	Not needed for xsl 2.0 lifted from http://www.xml.com/pub/a/2002/06/05/transforming.html -->
+	<xsl:template name="globalReplace">
+	  <xsl:param name="outputString"/>
+	  <xsl:param name="target"/>
+	  <xsl:param name="replacement"/>
+	  <xsl:choose>
+		<xsl:when test="contains($outputString,$target)">
+			"concat(substring-before($outputString,$target),
+				   $replacement)"/>
+				 select="substring-after($outputString,$target)"/>
+			<xsl:with-param name="target" select="$target"/>
+				 select="$replacement"/>
+		</xsl:when>
+		<xsl:otherwise>
+		  <xsl:value-of select="$outputString"/>
+		</xsl:otherwise>
+	  </xsl:choose>
+	</xsl:template>
+	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function.  -->
+	<xsl:template name="listparams">
+		<xsl:param name="func" />
+		<xsl:for-each select="$func">
+			<xsl:if test="count(paramdef/parameter) > 0">args: </xsl:if>
+			<xsl:for-each select="paramdef">
+				<xsl:choose>
+					<xsl:when test="count(parameter) > 0">
+						<xsl:value-of select="parameter" />
+					</xsl:when>
+				</xsl:choose>
+				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
+			</xsl:for-each>
+			<xsl:if test="count(paramdef/parameter) > 0"> - </xsl:if>
+		</xsl:for-each>
+	</xsl:template>
+</xsl:stylesheet>
