[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Sat Sep 9 05:01:45 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Comment (by laopsahl):
Test 2 fails with another message.
XX000: Invalid edge (no two distinct vertices exist)
CONTEXT: PL/pgSQL function totopogeom(geometry,topogeometry,double
precision) line 114 at FOR over SELECT rows
PL/pgSQL function totopogeom(geometry,character varying,integer,double
precision) line 89 at assignment
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:2>
