[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
PostGIS trac at osgeo.org
Sun Sep 10 00:10:37 PDT 2017
  Reporter:  laopsahl    |      Owner:  strk
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.3.4
 Component:  topology    |    Version:  2.3.x
Resolution:              |   Keywords:  totopogeom, ERROR:  XX000: SQL/MM
Changes (by laopsahl):
 * Attachment "failed_test_2.sql" removed.
 test 2 that fails
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838>
