[postgis-tickets] [PostGIS] #3840: winnie 32-bit test failing on protobuf geobuf regress tests (was: winnie 32-bit test failing on protobuf)
trac at osgeo.org
Sat Sep 9 21:33:25 PDT 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> I turned on 32-bit testing on winnie. Had it off for a long time because
> of the shp2pgsql cunit failures.
> To my disappointment getting errors on protobuf. I recall we had a
> similar issue like this with 64-bit.
> PostgreSQL 10beta2 on i686-w64-mingw32, compiled by
> i686-w64-mingw32-gcc.exe (rev2, Built by MinGW-W64 project) 4.8.1, 32-bit
> Postgis 2.4.0dev - r15675 - 2017-09-10 03:54:10
> scripts 2.4.0dev r15675
> GEOS: 3.6.2-CAPI-1.10.2 4d2925d
> PROJ: Rel. 4.9.1, 04 March 2015
> SFCGAL: 1.3.1
> geobuf .. failed (diff expected obtained:
> /projects/postgis/tmp/2.4.0dev_pg10_geos3.6.2_gdal2.2.1w32/test_120_diff)
> --- geobuf_expected 2017-09-08 18:24:34.086202800 -0400
> /projects/postgis/tmp/2.4.0dev_pg10_geos3.6.2_gdal2.2.1w32/test_120_out
> 2017-09-10 00:07:00.251494400 -0400
> @@ -1,4 +1,4 @@
> -T1|GAEiCgoICgYIABoCFio=
> +T1|GAIiDAoKCggIABoE3gGkAw==
> T2|Cgh0ZXN0X3N0cgoMdGVzdF9wb3NfaW50Cgx0ZXN0X25lZ19pbnQKDHRlc3RfbnVtZXJpYwoKdGVz
> dF9mbG9hdBgAIjoKOAoICAIaBAICAgJqBgoEdGVzdGoCGAFqAiABagUKAzEuMWoJEZqZmZmZmfE/
> cgoAAAEBAgIDAwQE
> I know got to upgrade her 10 to beta4, but that shouldn't matter.
New description:
To my disappointment getting errors on ST_AsGeobuf. I recall we had a
SFCGAL: 1.3.1
@@ -1,4 +1,4 @@
cgoAAAEBAgIDAwQE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:2>
