[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests (was: winnie 32-bit test failing on protobuf geobuf regress tests)
    trac at osgeo.org
    Sat Sep  9 22:38:30 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 well this is interesting the PostgreSQL 9.6.5 32-bit run passed this test.
 PostgreSQL 9.6.5, compiled by Visual C++ build 1800, 32-bit
   Postgis 2.4.0dev - r15675 - 2017-09-10 04:36:59
   scripts 2.4.0dev r15675
   GEOS: 3.6.2-CAPI-1.10.2 4d2925d
   PROJ: Rel. 4.9.1, 04 March 2015
   SFCGAL: 1.3.1
 mvt .. ok
  geobuf .. ok
  mvt_jsonb .. ok
  regress_sfcgal .. ok
 Only difference I can think is that 9.6 I do test against VC++ built
 PostgreSQL. 10 is mingw64-w32 since EDB hasn't released their 32-bit
 PostgreSQL 10 yet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:3>
