[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Sun Sep 10 00:10:37 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Changes (by laopsahl):
* Attachment "failed_test_2.sql" added.
Added create schema topo_ar5_forest and drop file if exists
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838>
