[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
PostGIS trac at osgeo.org
Fri Sep 15 21:39:32 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 You have to use the phrase References #ticket_num.
 note sure.  I had the 10 32-bit turned off. I'll turn it back and and
 close this out if it fixes the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:8>
