[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
trac at osgeo.org
Fri Sep 15 22:46:28 PDT 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Sadly still a problem. What's annoying is I can't replicate it on my
desktop. So it's not even a simple matter of pg10 32-bit windows since
using the same compiled cluster I can't replicate it. On winnie it only
happens on her pg10 32-bit runs. thought that may be because the others
are tested under Vc++ and this one is pure ming. Though even on my
machine where I have a pure mingw64-w32 test it doesn't fail. Can't
imagine its something as stupid as because she's running windows 2012 and
I'm running windows 7.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:9>
