[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
trac at osgeo.org
Sat Sep 16 20:55:44 PDT 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
okay I embarrassingly discovered that it fails on my desktop pg10x32 and
pg96x32 mingw64-w32 installs as well. So the good news is it's not some
weird spooky thing happening on winnie or with windows 2012r2. It's also
not specific to PostgreSQL 10.
I wasn't seeing the failure before because duh I wasn't compiling with
protobuf support.
Since it doesn't fail when testing against VC++ 32-bit builds (9.6), my
guess is it might be only something that shows with a cassert / debug
compiled PostgreSQL 32-bit and may not even have anything to do with vc++
vs. mingw64-w32 differences.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:10>
