[postgis-tickets] [PostGIS] #3852: float rounding using local hacks
trac at osgeo.org
Tue Sep 19 13:58:50 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
I found a regression failure when I ran my fix for this ticket, but the
problem appears to be in the *existing* behavior, not mine...
When adding a box to POINT(1e+15 1e+15), aka POINT(1000000000000000
1000000000000000) the regression suite says the result of the
ST_BoundingDiagonal should be LINESTRING(999999986991104
999999986991104,999999986991104 999999986991104)
Wait a sec, that box doesn't enclose the original point! Huge fail! My new
code does enclose it, with LINESTRING(999999986991104
999999986991104,1.00000005409997e+15 1.00000005409997e+15).
I wouldn't ordinarily commit a fix that changes regression so late in the
day, but in this case, it seems an improvement. Hopefully the other
platforms agree.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3852#comment:1>
