[postgis-tickets] [PostGIS] #3852: float rounding using local hacks
trac at osgeo.org
Tue Sep 19 14:02:07 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"15772" 15772]:
#!CommitTicketReference repository="" revision="15772"
Remove the local hacks for float rounding and go
with system level functions, that are hopefully
more optimized. Also, this seems to provide more
correct results than the old code!
(Closes #3852)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3852#comment:2>
