[postgis-tickets] r15776 - ST_ConcaveHull fix for ExteriorRing is not a polygon
Regina Obe
lr at pcorp.us
Tue Sep 19 17:19:17 PDT 2017
Author: robe
Date: 2017-09-19 17:19:16 -0700 (Tue, 19 Sep 2017)
New Revision: 15776
branches/2.3/NEWS
branches/2.3/postgis/postgis.sql.in
References #2836 for PostGIS 2.3.4
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2017-09-20 00:12:52 UTC (rev 15775)
+++ branches/2.3/NEWS 2017-09-20 00:19:16 UTC (rev 15776)
@@ -18,6 +18,8 @@
also reenable cunit loader tess to always run.
- #3774, Trigonometric length for CompoundCurves
- #3731, Crash on very small table of homogenous data
+ - #2836, Receiving ERROR: ExteriorRing: geom is
+ not a polygon with ST_ConcaveHull
PostGIS 2.3.3
Modified: branches/2.3/postgis/postgis.sql.in
--- branches/2.3/postgis/postgis.sql.in 2017-09-20 00:12:52 UTC (rev 15775)
+++ branches/2.3/postgis/postgis.sql.in 2017-09-20 00:19:16 UTC (rev 15776)
@@ -5720,8 +5720,10 @@
var_tempgeom := @extschema at .ST_ForceSFS(@extschema at .ST_Intersection(var_tempgeom, var_convhull));
IF param_allow_holes THEN
var_param_geom := var_tempgeom;
+ ELSIF @extschema at .ST_GeometryType(var_tempgeom) = 'ST_Polygon' THEN
+ var_param_geom := @extschema at .ST_MakePolygon(@extschema at .ST_ExteriorRing(var_tempgeom));
ELSE
- var_param_geom := @extschema at .ST_MakePolygon(@extschema at .ST_ExteriorRing(var_tempgeom));
+ var_param_geom := @extschema at .ST_ConvexHull(var_param_geom);
END IF;
return var_param_geom;
ELSIF @extschema at .ST_IsValid(var_tempgeom) THEN
