[postgis-tickets] r15777 - ST_ConcaveHull fix for ExteriorRing is not a polygon
Regina Obe
lr at pcorp.us
Tue Sep 19 20:52:42 PDT 2017
Author: robe
Date: 2017-09-19 20:52:42 -0700 (Tue, 19 Sep 2017)
New Revision: 15777
branches/2.2/NEWS
branches/2.2/postgis/postgis.sql.in
Closes #2836 for PostGIS 2.2.6
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2017-09-20 00:19:16 UTC (rev 15776)
+++ branches/2.2/NEWS 2017-09-20 03:52:42 UTC (rev 15777)
@@ -5,6 +5,8 @@
- #3786, ptarray null and heap issues on is_closed
- #3774, Trigonometric length for CompoundCurves
- #3731, Crash on very small table of homogenous data
+ - #2836, Receiving ERROR: ExteriorRing: geom is
+ not a polygon with ST_ConcaveHull
PostGIS 2.2.5
Modified: branches/2.2/postgis/postgis.sql.in
--- branches/2.2/postgis/postgis.sql.in 2017-09-20 00:19:16 UTC (rev 15776)
+++ branches/2.2/postgis/postgis.sql.in 2017-09-20 03:52:42 UTC (rev 15777)
@@ -5578,8 +5578,10 @@
var_tempgeom := ST_ForceSFS(ST_Intersection(var_tempgeom, var_convhull));
IF param_allow_holes THEN
var_param_geom := var_tempgeom;
+ ELSIF ST_GeometryType(var_tempgeom) = 'ST_Polygon' THEN
+ var_param_geom := ST_MakePolygon(ST_ExteriorRing(var_tempgeom));
ELSE
- var_param_geom := ST_MakePolygon(ST_ExteriorRing(var_tempgeom));
+ var_param_geom := ST_ConvexHull(var_tempgeom);
END IF;
return var_param_geom;
ELSIF ST_IsValid(var_tempgeom) THEN
