[postgis-tickets] r15779 - Short circuit ST_RepeatedPoints right away on point inputs (Closes #3854)
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 20 12:55:56 PDT 2017
Author: pramsey
Date: 2017-09-20 12:55:56 -0700 (Wed, 20 Sep 2017)
New Revision: 15779
trunk/postgis/lwgeom_functions_basic.c
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2017-09-20 15:46:14 UTC (rev 15778)
+++ trunk/postgis/lwgeom_functions_basic.c 2017-09-20 19:55:56 UTC (rev 15779)
@@ -2632,15 +2632,21 @@
PG_FUNCTION_INFO_V1(ST_RemoveRepeatedPoints);
Datum ST_RemoveRepeatedPoints(PG_FUNCTION_ARGS)
- GSERIALIZED *g_in = PG_GETARG_GSERIALIZED_P_COPY(0);
+ GSERIALIZED *g_in = PG_GETARG_GSERIALIZED_P(0);
+ int type = gserialized_get_type(g_in);
GSERIALIZED *g_out;
- LWGEOM *lwgeom_in = lwgeom_from_gserialized(g_in);
+ LWGEOM *lwgeom_in = NULL;
LWGEOM *lwgeom_out = NULL;
double tolerance = 0.0;
+ /* Don't even start to think about points */
+ if ( type == POINTTYPE )
+ PG_RETURN_POINTER(g_in);
if ( PG_NARGS() > 1 && ! PG_ARGISNULL(1) )
tolerance = PG_GETARG_FLOAT8(1);
+ lwgeom_in = lwgeom_from_gserialized(g_in);
lwgeom_out = lwgeom_remove_repeated_points(lwgeom_in, tolerance);
g_out = geometry_serialize(lwgeom_out);
