[postgis-tickets] [PostGIS] #3855: TWKB generations works too much on the heap
trac at osgeo.org
Wed Sep 20 12:57:34 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: |
Checking a profile of TWKB it becomes pretty clear that for large numbers
of small objects it spends an inordinate amount of time allocating and
deallocating memory, mostly handling bytebuffers on the heap. Sticking
those buffers on the stack, and also having the buffers use a default
static buffer initially makes things *much* faster.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3855>
