[postgis-tickets] [PostGIS] #3858: ST_AsMVT doesn't support geometry collections should be noted
trac at osgeo.org
Fri Sep 22 06:43:41 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: documentation | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I'm a bit confused here. Why does ST_AsMVT not work with geometry
collections, but ST_AsGeoBuf and ST_AsMVTGeom do?
SELECT encode(ST_AsGeobuf(foo1, 'the_geom'), 'base64')
FROM ((SELECT
ST_Collect(geom) As the_geom
FROM (VALUES (
ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822
42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.1261 42.2703 1,-71.1257
42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261
42.2703 1))') ) ) As g(geom) CROSS JOIN generate_series(1,3) As i GROUP BY
i )) As foo1 LIMIT 10;
outputs
EAMi5wEKSwpJCAYiIwgFEgMBAQQaGueB5UPggawogJL0AccBAACQA5ADAMgBxwEAIiAIBBocp7Hq
Q7j5pyiAiXqgBgAAAI8DANcEAADHAcgBAApLCkkIBiIjCAUSAwEBBBoa54HlQ+CBrCiAkvQBxwEA
AJADkAMAyAHHAQAiIAgEGhynsepDuPmnKICJeqAGAAAAjwMA1wQAAMcByAEACksKSQgGIiMIBRID
AQEEGhrngeVD4IGsKICS9AHHAQAAkAOQAwDIAccBACIgCAQaHKex6kO4+acogIl6oAYAAACPAwDX
BAAAxwHIAQA=
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3858#comment:1>
