[postgis-tickets] [PostGIS] #3858: ST_AsMVT doesn't support geometry collections should be noted
trac at osgeo.org
Fri Sep 22 07:03:30 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: documentation | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"15794" 15794]:
#!CommitTicketReference repository="" revision="15794"
Use ansi standard names for arg types for ST_AsMVT and ST_AsMVTGeom to be
consistent with rest of docs. Note that ST_AsMVT should not be used with
geometry collection directly, but a geometry collection can be converted
to suitable form with ST_AsMVTGeom.
More adjustments to support garden testing ST_AsMVT and ST_AsMVTGeom
Closes #3858
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3858#comment:2>
