[postgis-tickets] [PostGIS] #4115: MVT: Incorrect keys with parallel mode
trac at osgeo.org
Tue Jul 3 10:25:28 PDT 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
While testing MVT parallel mode a colleague noticed than the last feature
was showing random values from its keys. After some digging I've
discovered that the combine function had a bug and the second tile
properties weren't indexed properly.
I have a fix in https://github.com/postgis/postgis/pull/263 but I'm still
thinking on a way to test in the regression tests.
Only affects trunk (2.4 doesn't have the parallel implementation) so it
should be fixed before the final release of 2.5.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4115>
