[postgis-tickets] [PostGIS] #4115: MVT: Incorrect keys with parallel mode
trac at osgeo.org
Fri Jul 6 04:22:00 PDT 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"16636" 16636]:
#!CommitTicketReference repository="" revision="16636"
MVT combine: Fix bug with invalid property values
Closes #4115
Closes https://github.com/postgis/postgis/pull/263
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4115#comment:1>
