[postgis-tickets] r16630 - Prepping for 2.5.0beta1 release
Regina Obe
lr at pcorp.us
Tue Jul 3 11:04:37 PDT 2018
Author: robe
Date: 2018-07-03 11:04:37 -0700 (Tue, 03 Jul 2018)
New Revision: 16630
trunk/ChangeLog
trunk/NEWS
trunk/Version.config
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2018-07-01 16:30:51 UTC (rev 16629)
+++ trunk/ChangeLog 2018-07-03 18:04:37 UTC (rev 16630)
@@ -1,3 +1,238 @@
+2018-07-01 16:30 Regina Obe <lr at pcorp.us>
+ * [r16629] libpgcommon/gserialized_gist.h: Get rid of the ifdefs
+ around the functions, these have always existed but were static
+ before.
+ Closes #4114
+2018-07-01 15:42 Regina Obe <lr at pcorp.us>
+ * [r16628] NEWS: fix typos in last credits
+2018-07-01 15:39 Regina Obe <lr at pcorp.us>
+ * [r16627] NEWS: Minor update to the credits
+2018-07-01 15:34 Regina Obe <lr at pcorp.us>
+ * [r16626] NEWS, configure.ac, libpgcommon/gserialized_gist.h,
+ libpgcommon/lwgeom_pg.h, postgis/Makefile.in,
+ postgis/gserialized_gist_2d.c, postgis/gserialized_spgist_2d.c,
+ postgis/gserialized_spgist_3d.c, postgis/gserialized_spgist_3d.h,
+ postgis/lwgeom_box3d.c, postgis/postgis.sql.in,
+ postgis/postgis_spgist.sql.in, regress/Makefile.in,
+ regress/regress_spgist_index_2d.data,
+ regress/regress_spgist_index_2d.sql,
+ regress/regress_spgist_index_2d_expected,
+ regress/regress_spgist_index_3d.data,
+ regress/regress_spgist_index_3d.sql,
+ regress/regress_spgist_index_3d_expected: spgist 2d and 3d
+ support for PG 11+
+ references #1847
+ Credits: Arthur Lesuisse, Esteban Zimanyi from Université Libre
+ de Bruxelles (ULB) and Darafei Praliaskouski
+ also added logic to exclude PG < 11 from including this
+ functionality
+ Closes https://github.com/postgis/postgis/pull/258
+2018-06-30 21:59 Regina Obe <lr at pcorp.us>
+ * [r16625] topology/test/regress/topogeo_addlinestring.sql,
+ topology/test/regress/topogeo_addlinestring_expected: Make test
+ sort order deterministic by using lateral.
+ Closes #4111
+ (Note they are going to fix the issue upstream that made this
+ fail on stable 10, but I wanted to change this test anyway)
+2018-06-26 14:55 Daniel Baston <dbaston at gmail.com>
+ * [r16624] doc/reference_constructor.xml: Add spaces in
+ documentation
+ Patch from hannes
+ Closes https://gitlab.com/postgis/postgis/merge_requests/10
+2018-06-18 21:47 Regina Obe <lr at pcorp.us>
+ * [r16623] doc/reference_processing.xml: fix spacing
+2018-06-18 21:46 Regina Obe <lr at pcorp.us>
+ * [r16622] doc/reference_processing.xml: Fix availability note of
+ ST_OrientedEnvelope so it shows in new functions section
+2018-06-17 09:33 Regina Obe <lr at pcorp.us>
+ * [r16621] doc/reference_accessor.xml: Link to ST_OrientedEnvelope
+ from ST_Envelope
+2018-06-17 08:41 Regina Obe <lr at pcorp.us>
+ * [r16620] doc/html/image_src/Makefile.in,
+ doc/html/image_src/st_envelope01.wkt,
+ doc/html/image_src/st_orientedenvelope01.wkt,
+ doc/reference_accessor.xml, doc/reference_processing.xml: Add
+ graphical examples for ST_Envelope and ST_OrientedEnvelope
+2018-06-15 22:16 Sandro Santilli <strk at kbt.io>
+ * [r16618] liblwgeom/cunit/cu_lwstroke.c, liblwgeom/lwstroke.c: Fix
+ infinite loop in linearization of a big radius small arc
+ Ref #4058 for trunk (2.5.0dev)
+ Includes unit test
+2018-06-13 14:19 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16616] regress/mvt.sql, regress/mvt_expected: MVT tests: Remove
+ ST_Normalize calls
+ References #4106
+2018-06-13 14:16 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16615] .travis.yml: Travis: Install all required dependencies
+ for MVT tests
+ References #4106
+2018-06-12 01:38 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16612] liblwgeom/g_serialized.c: Fix flags in case where a
+ boxless geom comes in with a "has box" set of flags.
+ References #4707
+2018-06-06 18:01 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16611] postgis/postgis.sql.in: Remove erroneous commutator
+ definitions for over(left/right/above/below)
+ operators. Closes #4088
+2018-06-06 09:29 Darafei Praliaskouski <me at komzpa.net>
+ * [r16610] regress/tickets.sql: Debbie / Postgres 9.4 calls
+ function twice.
+ References #4103
+2018-06-05 17:11 Darafei Praliaskouski <me at komzpa.net>
+ * [r16609] NEWS, liblwgeom/liblwgeom.h.in, liblwgeom/lwgeom_geos.c,
+ postgis/lwgeom_geos.c, regress/tickets.sql,
+ regress/tickets_expected: ST_PointOnSurface handling of invalid.
+ Prints a loud notice and passes input through MakeValid.
+ Closes #4103
+ Closes https://github.com/postgis/postgis/pull/257
+2018-06-05 14:40 Darafei Praliaskouski <me at komzpa.net>
+ * [r16608] NEWS, postgis/lwgeom_geos.c, postgis/postgis.sql.in:
+ Unify geometry centroid functions
+ Make ST_Centroid call lwgeom_centroid.
+ Closes #3960
+ Closes https://github.com/postgis/postgis/pull/256
+2018-06-05 12:28 Darafei Praliaskouski <me at komzpa.net>
+ * [r16607] liblwgeom/cunit/cu_clip_by_rect.c,
+ liblwgeom/cunit/cu_geos.c, liblwgeom/liblwgeom.h.in,
+ liblwgeom/lwgeom_geos.c, postgis/lwgeom_dump.c,
+ postgis/lwgeom_geos.c, postgis/mvt.c, postgis/postgis_module.c,
+ regress/node.sql: Remove mentions of GEOS <= 3.5.0.
+ PostGIS requires 3.5.0 already.
+ Closes https://github.com/postgis/postgis/pull/255
+2018-06-03 09:11 Darafei Praliaskouski <me at komzpa.net>
+ * [r16605] liblwgeom/lwkmeans.c, regress/cluster.sql,
+ regress/cluster_expected: ST_ClusterKMeans: handle effective K=0
+ when all the inputs are EMPTY
+ Closes #4101
+ Closes https://github.com/postgis/postgis/pull/254
+2018-06-02 12:09 Darafei Praliaskouski <me at komzpa.net>
+ * [r16604] liblwgeom/lwkmeans.c, regress/cluster.sql,
+ regress/cluster_expected: Let KMeans init even if there are only
+ duplicates in input
+ Added reporting of duplicates noticed on init pass.
+ Closes #4100
+ Closes https://github.com/postgis/postgis/pull/253
+2018-06-02 05:39 Regina Obe <lr at pcorp.us>
+ * [r16603] doc/xsl/postgis_gardentest.sql.xsl,
+ doc/xsl/raster_gardentest.sql.xsl: change to version 2.5.0 and
+ have table generated be 25
+2018-06-01 13:38 Darafei Praliaskouski <me at komzpa.net>
+ * [r16602] doc/using_postgis_dataman.xml: [doc] fix invalid xml
+ make check skips it for me locally for some reason.
+2018-06-01 13:29 Darafei Praliaskouski <me at komzpa.net>
+ * [r16601] doc/using_postgis_dataman.xml: [doc] Update index usage
+ troubleshooting section
+ Contains typo fixes reported by Yaroslav Schekin in
+ https://t.me/pgsql
+2018-06-01 11:20 Darafei Praliaskouski <me at komzpa.net>
+ * [r16600] doc/using_postgis_dataman.xml: [doc] fix xml structure
+2018-06-01 11:00 Darafei Praliaskouski <me at komzpa.net>
+ * [r16599] doc/using_postgis_dataman.xml: [doc] dbmanagement manual
+ pass
+ Removed some dust, references to PostGIS 1 and Postgres 7.
+2018-05-31 10:20 Sandro Santilli <strk at kbt.io>
+ * [r16598] NEWS: Add entry about upgrade script symlinks
+2018-05-30 18:32 Darafei Praliaskouski <me at komzpa.net>
+ * [r16597] doc/html/image_src/generator.c: Fix typo in drawPoint()
+ in doc images generator.
+ Issue introduced in r16296
+ Closes #4098
+ Closes https://github.com/postgis/postgis/pull/252
+2018-05-29 08:06 Sandro Santilli <strk at kbt.io>
+ * [r16596] liblwgeom/lwalgorithm.c: Fix function comment for
+ lw_arc_center
+2018-05-28 23:45 Regina Obe <lr at pcorp.us>
+ * [r16595] Version.config, extensions/upgradeable_versions.mk: Flip
+ to 2.5.0beta1dev
+2018-05-28 23:21 Regina Obe <lr at pcorp.us>
+ * [r16593] doc/release_notes.xml: Add in Enhancements and Fixes
+ section for PostGIS 2.5.0alpha
+2018-05-28 23:02 Regina Obe <lr at pcorp.us>
+ * [r16592] ChangeLog, NEWS, Version.config, doc/release_notes.xml:
+ In prep for PostGIS 2.5.0alpha release
2018-05-28 22:49 Regina Obe <lr at pcorp.us>
* [r16591] postgis/lwgeom_accum.c: put back pgis_abs_in and
Modified: trunk/NEWS
--- trunk/NEWS 2018-07-01 16:30:51 UTC (rev 16629)
+++ trunk/NEWS 2018-07-03 18:04:37 UTC (rev 16630)
@@ -1,3 +1,14 @@
+PostGIS 2.5.0beta1
+2018/07/03
+New since PostGIS 2.5.0alpha
+ - #1847, spgist 2d and 3d support for PG 11+
+ (Esteban Zimányi and Arthur Lesuisse from Université Libre de Bruxelles (ULB),
+ Darafei Praliaskouski)
+ - Numerous packaging fixes
+ See PostGIS 2.5.0 section for full details
PostGIS 2.5.0alpha
2018/05/28
See PostGIS 2.5.0 section for details
Modified: trunk/Version.config
--- trunk/Version.config 2018-07-01 16:30:51 UTC (rev 16629)
+++ trunk/Version.config 2018-07-03 18:04:37 UTC (rev 16630)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=0beta1dev
+POSTGIS_MICRO_VERSION=0beta1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
