[postgis-tickets] [PostGIS] #4123: Fix postgis_tiger_geocoder.control generation
PostGIS trac at osgeo.org
Fri Jul 13 16:28:19 PDT 2018
 Reporter:  komzpa   |      Owner:  komzpa
     Type:  patch    |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 2.4.5
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 Commit 639308e moved the
 postgis_tiger_geocoder.control into the Makefile, but forgot to remove
 the file from configure.ac, which still generates the file, so the
 Makefile rule is not effective and the resulting .control file has the
 raw @EXTVERSION@ line from the .in file.
 Patch: https://github.com/postgis/postgis/pull/270
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4123>
