[postgis-tickets] [PostGIS] #4123: Fix postgis_tiger_geocoder.control generation
PostGIS trac at osgeo.org
Fri Jul 13 16:30:58 PDT 2018
  Reporter:  komzpa   |      Owner:  komzpa
      Type:  patch    |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.4.5
 Component:  postgis  |    Version:  2.4.x
Resolution:  fixed    |   Keywords:
Changes (by komzpa):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16644" 16644]:
 #!CommitTicketReference repository="" revision="16644"
 Patch by Christoph Berg
 Commit 639308e moved the postgis_tiger_geocoder.control into the
 Makefile, but forgot to remove the file from configure.ac, which still
 generates the file, so the Makefile rule is not effective and the
 resulting .control file has the raw @EXTVERSION@ line from the .in file.
 Closes #4123
 Closes https://github.com/postgis/postgis/pull/270
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4123#comment:1>
