[postgis-tickets] r16645 - Fix raster notices.
Darafei komzpa at gmail.com
Sat Jul 14 03:00:34 PDT 2018
Author: komzpa
Date: 2018-07-14 15:00:33 -0700 (Sat, 14 Jul 2018)
New Revision: 16645
   trunk/raster/rt_core/rt_mapalgebra.c
   trunk/raster/rt_core/rt_raster.c
   trunk/raster/rt_core/rt_spatial_relationship.c
   trunk/raster/rt_pg/rtpg_create.c
   trunk/raster/rt_pg/rtpg_gdal.c
   trunk/raster/rt_pg/rtpg_geometry.c
   trunk/raster/rt_pg/rtpg_mapalgebra.c
   trunk/raster/rt_pg/rtpg_statistics.c
   trunk/raster/test/cunit/cu_mapalgebra.c
Fix raster notices.
References #3994
Closes https://github.com/postgis/postgis/pull/271
Modified: trunk/raster/rt_core/rt_mapalgebra.c
--- trunk/raster/rt_core/rt_mapalgebra.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_core/rt_mapalgebra.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -1015,7 +1015,7 @@
 			for (i = 0; i < itrcount; i++) {
 				if (!_param->isempty[i]) {
-					memcpy(rtnrast, _param->raster[i], sizeof(struct rt_raster_serialized_t));
+					memcpy(rtnrast, _param->raster[i], sizeof(struct rt_raster_t));
 					break;
@@ -1118,11 +1118,11 @@
 			switch (extenttype) {
 				case ET_CUSTOM:
-					memcpy(rtnrast, customextent, sizeof(struct rt_raster_serialized_t));
+					memcpy(rtnrast, customextent, sizeof(struct rt_raster_t));
 					break;
 				/* first, second, last */
 				default:
 					break;
 			rtnrast->numBands = 0;
Modified: trunk/raster/rt_core/rt_raster.c
--- trunk/raster/rt_core/rt_raster.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_core/rt_raster.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -1262,11 +1262,11 @@
 			return NULL;
-		if (covers)
-			break;
-		raster->width++;
-		raster->height++;
+		if (!covers)
+			raster->width++;
+			raster->height++;
 	while (!covers);
@@ -1309,17 +1309,13 @@
 				rt_raster_destroy(raster);
 				return NULL;
+		} while (covers);
-			if (!covers) {
-				if (i < 1)
-					raster->width++;
-				else
-					raster->height++;
+		if (i < 1)
+			raster->width++;
+		else
+			raster->height++;
-				break;
-		while (covers);
 	GEOSGeom_destroy(ngeom);
@@ -1336,7 +1332,7 @@
 int
 rt_raster_is_empty(rt_raster raster) {
-	return (NULL == raster || raster->height <= 0 || raster->width <= 0);
+	return (!raster || raster->height == 0 || raster->width == 0);
@@ -2783,7 +2779,7 @@
 			/* check alignment flag: grid_xw */
 			if (
 				(NULL == ul_xw && NULL == ul_yw) &&
-				(NULL != grid_xw && NULL != grid_xw) &&
+				(NULL != grid_xw && NULL != grid_yw) &&
 				FLT_NEQ(*grid_xw, extent.MinX)
 				/* do nothing */
@@ -2798,7 +2794,7 @@
 			/* check alignment flag: grid_yw */
 			if (
 				FLT_NEQ(*grid_yw, extent.MaxY)
 				/* do nothing */
@@ -2815,7 +2811,7 @@
 			if (
 				/* do nothing */
@@ -2831,7 +2827,7 @@
 			if (
 				/* do nothing */
Modified: trunk/raster/rt_core/rt_spatial_relationship.c
--- trunk/raster/rt_core/rt_spatial_relationship.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_core/rt_spatial_relationship.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -995,7 +995,6 @@
 	int *intersects
 	int i;
-	int j;
 	int within = 0;
 	LWGEOM *hull[2] = {NULL};
@@ -1069,28 +1068,29 @@
 		initGEOS(rtinfo, lwgeom_geos_error);
 		rtn = 1;
-		for (i = 0; i < 2; i++) {
-			if ((rt_raster_get_convex_hull(i < 1 ? rast1 : rast2, &(hull[i])) != ES_NONE) || NULL == hull[i]) {
-				for (j = 0; j < i; j++) {
-					GEOSGeom_destroy(ghull[j]);
-					lwgeom_free(hull[j]);
-				rtn = 0;
-				break;
-			ghull[i] = (GEOSGeometry *) LWGEOM2GEOS(hull[i], 0);
-			if (NULL == ghull[i]) {
-				lwgeom_free(hull[i]);
-				rtn = 0;
-				break;
+		if ((rt_raster_get_convex_hull(rast1, &(hull[0])) != ES_NONE) || !hull[0]) {
+			break;
-		if (!rtn) break;
+		ghull[0] = (GEOSGeometry *) LWGEOM2GEOS(hull[0], 0);
+		if (!ghull[0]) {
+			lwgeom_free(hull[0]);
+			break;
+		if ((rt_raster_get_convex_hull(rast2, &(hull[1])) != ES_NONE) || !hull[1]) {
+			GEOSGeom_destroy(ghull[0]);
+			break;
+		ghull[1] = (GEOSGeometry *) LWGEOM2GEOS(hull[1], 0);
+		if (!ghull[0]) {
+			lwgeom_free(hull[1]);
+			break;
 		/* test to see if raster within the other */
 		within = 0;
 		if (GEOSWithin(ghull[0], ghull[1]) == 1)
Modified: trunk/raster/rt_pg/rtpg_create.c
--- trunk/raster/rt_pg/rtpg_create.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_pg/rtpg_create.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -1312,7 +1312,7 @@
 				int nband = arg2->nbands[i] + 1;
 				rt_raster_destroy(tile);
 				rt_raster_destroy(arg2->raster.raster);
-				if (arg2->numbands) pfree(arg2->nbands);
+				pfree(arg2->nbands);
 				pfree(arg2);
 				elog(ERROR, "RASTER_tile: Could not get band %d from source raster", nband);
 				SRF_RETURN_DONE(funcctx);
@@ -1343,7 +1343,7 @@
 				if (band == NULL) {
 					pfree(arg2);
 					elog(ERROR, "RASTER_tile: Could not get newly added band from output tile");
@@ -1368,7 +1368,7 @@
 					if (rt_band_get_pixel_line(_band, rx, k, len, &vals, &nvals) != ES_NONE) {
 						pfree(arg2);
 						elog(ERROR, "RASTER_tile: Could not get pixel line from source raster");
@@ -1377,7 +1377,7 @@
 					if (nvals && rt_band_set_pixel_line(band, 0, j, vals, nvals) != ES_NONE) {
 						pfree(arg2);
 						elog(ERROR, "RASTER_tile: Could not set pixel line of output tile");
@@ -1399,7 +1399,7 @@
 				if (band == NULL) {
 					pfree(arg2);
 					elog(ERROR, "RASTER_tile: Could not create new offline band for output tile");
@@ -1409,7 +1409,7 @@
 					rt_band_destroy(band);
 					pfree(arg2);
 					elog(ERROR, "RASTER_tile: Could not add new offline band to output tile");
@@ -1482,9 +1482,7 @@
 		elog(NOTICE, "Band number(s) not provided.  Returning original raster");
 		skip = TRUE;
-	do {
-		if (skip) break;
+	if (!skip) {
 		numBands = rt_raster_get_num_bands(raster);
 		array = PG_GETARG_ARRAYTYPE_P(1);
@@ -1521,7 +1519,7 @@
 			POSTGIS_RT_DEBUGF(3, "band idx (before): %d", idx);
 			if (idx > numBands || idx < 1) {
-        elog(NOTICE, "Invalid band index (must use 1-based). Returning original raster");
+        		elog(NOTICE, "Invalid band index (must use 1-based). Returning original raster");
 				skip = TRUE;
 				break;
@@ -1536,7 +1534,6 @@
 			skip = TRUE;
-	while (0);
 	if (!skip) {
 		rast = rt_raster_from_band(raster, bandNums, j);
Modified: trunk/raster/rt_pg/rtpg_gdal.c
--- trunk/raster/rt_pg/rtpg_gdal.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_pg/rtpg_gdal.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -250,7 +250,7 @@
 				if (strlen(option)) {
 					options[j] = (char *) palloc(sizeof(char) * (strlen(option) + 1));
-					options[j] = option;
+					strcpy(options[j], option);
 					j++;
@@ -323,15 +323,8 @@
 	SET_VARSIZE(result, result_size);
 	memcpy(VARDATA(result), gdal, VARSIZE(result) - VARHDRSZ);
-	/* for test output
-	FILE *fh = NULL;
-	fh = fopen("/tmp/out.dat", "w");
-	fwrite(gdal, sizeof(uint8_t), gdal_size, fh);
-	fclose(fh);
 	/* free gdal mem buffer */
-	if (gdal) CPLFree(gdal);
+	CPLFree(gdal);
 	POSTGIS_RT_DEBUG(3, "RASTER_asGDALRaster: Returning pointer to GDAL raster");
 	PG_RETURN_POINTER(result);
@@ -649,7 +642,7 @@
 		dst_srs = rtpg_getSR(dst_srid);
 		if (NULL == dst_srs) {
-			if (!no_srid) pfree(src_srs);
+			pfree(src_srs);
 			PG_FREE_IF_COPY(pgraster, 0);
 			elog(ERROR, "RASTER_GDALWarp: Target SRID (%d) is unknown", dst_srid);
Modified: trunk/raster/rt_pg/rtpg_geometry.c
--- trunk/raster/rt_pg/rtpg_geometry.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_pg/rtpg_geometry.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -1199,7 +1199,7 @@
 	/* all touched */
 	if (!PG_ARGISNULL(14) && PG_GETARG_BOOL(14) == TRUE) {
-		if (options_len < 1) {
+		if (options_len == 0) {
 			options_len = 1;
 			options = (char **) palloc(sizeof(char *) * options_len);
@@ -1209,7 +1209,7 @@
 		options[options_len - 1] = palloc(sizeof(char*) * (strlen("ALL_TOUCHED=TRUE") + 1));
-		options[options_len - 1] = "ALL_TOUCHED=TRUE";
+		strcpy(options[options_len - 1], "ALL_TOUCHED=TRUE");
 	if (options_len) {
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -1050,7 +1050,7 @@
 	rtpg_nmapalgebraexpr_callback_arg *callback = (rtpg_nmapalgebraexpr_callback_arg *) userarg;
 	SPIPlanPtr plan = NULL;
 	int i = 0;
-	int id = -1;
+	uint8_t id = 0;
 	if (arg == NULL)
 		return 0;
@@ -4715,8 +4715,7 @@
         POSTGIS_RT_DEBUGF(4, "RASTER_mapAlgebraExpr: New raster now has %d bands",
                 rt_raster_get_num_bands(newrast));
-        if (initexpr)
-            pfree(initexpr);
+        pfree(initexpr);
@@ -7004,13 +7003,13 @@
 						else if (spi_plan[i] != NULL) {
 							POSTGIS_RT_DEBUGF(4, "Using prepared plan: %d", i);
+							/* reset values to (Datum) NULL */
+							memset(values, (Datum) NULL, sizeof(Datum) * argkwcount);
+							/* reset nulls to FALSE */
+							memset(nulls, FALSE, sizeof(char) * argkwcount);
 							/* expression has argument(s) */
 							if (spi_argcount[i]) {
-								/* reset values to (Datum) NULL */
-								memset(values, (Datum) NULL, sizeof(Datum) * argkwcount);
-								/* reset nulls to FALSE */
-								memset(nulls, FALSE, sizeof(char) * argkwcount);
 								/* set values and nulls */
 								for (j = 0; j < argkwcount; j++) {
 									idx = argpos[i][j];
Modified: trunk/raster/rt_pg/rtpg_statistics.c
--- trunk/raster/rt_pg/rtpg_statistics.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/rt_pg/rtpg_statistics.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -309,13 +309,11 @@
 	SPI_cursor_fetch(portal, TRUE, 1);
 	while (SPI_processed == 1 && SPI_tuptable != NULL) {
 		tupdesc = SPI_tuptable->tupdesc;
-		tuptable = SPI_tuptable;
-		tuple = tuptable->vals[0];
+		tuple = SPI_tuptable->vals[0];
 		datum = SPI_getbinval(tuple, tupdesc, 1, &isNull);
 		if (SPI_result == SPI_ERROR_NOATTRIBUTE) {
-			if (SPI_tuptable) SPI_freetuptable(tuptable);
+			SPI_freetuptable(SPI_tuptable);
 			SPI_cursor_close(portal);
 			SPI_finish();
@@ -332,8 +330,7 @@
 		raster = rt_raster_deserialize(pgraster, FALSE);
 		if (!raster) {
 			SPI_finish();
@@ -349,7 +346,7 @@
 			SPI_finish();
@@ -364,7 +361,7 @@
 			SPI_finish();
@@ -381,7 +378,7 @@
 		if (NULL == stats) {
 			elog(NOTICE, "Cannot compute summary statistics for band at index %d. Returning NULL", bandindex);
 			SPI_finish();
@@ -394,8 +391,7 @@
 			if (NULL == rtn) {
 				rtn = (rt_bandstats) SPI_palloc(sizeof(struct rt_bandstats_t));
 				if (NULL == rtn) {
 					SPI_finish();
@@ -431,7 +427,7 @@
+	if (SPI_tuptable) SPI_freetuptable(SPI_tuptable);
 	SPI_finish();
@@ -1229,7 +1225,6 @@
 		double max = 0;
 		int spi_result;
 		Portal portal;
-		SPITupleTable *tuptable = NULL;
 		HeapTuple tuple;
 		Datum datum;
 		bool isNull = FALSE;
@@ -1391,7 +1386,7 @@
 		sql = (char *) palloc(len);
 		if (NULL == sql) {
 			SPI_finish();
 			if (bin_width_count) pfree(bin_width);
@@ -1408,7 +1403,7 @@
 		pfree(sql);
 		if (spi_result != SPI_OK_SELECT || SPI_tuptable == NULL || SPI_processed != 1) {
 			SPI_finish();
@@ -1419,13 +1414,12 @@
 		tmp = SPI_getvalue(tuple, tupdesc, 1);
 		if (NULL == tmp || !strlen(tmp)) {
 			SPI_finish();
@@ -1441,7 +1435,7 @@
 		tmp = SPI_getvalue(tuple, tupdesc, 2);
 			SPI_finish();
@@ -1460,7 +1454,7 @@
 		if (NULL == sql) {
 			SPI_finish();
@@ -1486,13 +1480,11 @@
 				SPI_finish();
@@ -1513,7 +1505,7 @@
 			if (!raster) {
 				SPI_finish();
@@ -1532,7 +1524,7 @@
 				SPI_finish();
@@ -1550,7 +1542,7 @@
 				SPI_finish();
@@ -1570,7 +1562,7 @@
 				SPI_finish();
@@ -1588,7 +1580,7 @@
 				if (NULL == hist || !count) {
 					elog(NOTICE, "Cannot compute histogram for band at index %d", bandindex);
 					SPI_finish();
@@ -1607,7 +1599,7 @@
 					if (NULL == covhist) {
 						pfree(hist);
 						SPI_finish();
@@ -1643,7 +1635,7 @@
 		SPI_finish();
@@ -2228,13 +2220,11 @@
 			if (NULL != covquant) pfree(covquant);
 				SPI_finish();
@@ -2252,7 +2242,7 @@
 			if (!raster) {
 				SPI_finish();
@@ -2268,7 +2258,7 @@
 				SPI_finish();
@@ -2283,7 +2273,7 @@
 				SPI_finish();
@@ -2302,10 +2292,10 @@
-			if (NULL == covquant || !count) {
+			if (!covquant || !count) {
 				elog(NOTICE, "Cannot compute quantiles for band at index %d", bandindex);
 				SPI_finish();
@@ -2325,10 +2315,10 @@
 				covquant2[i].value = covquant[i].value;
-		if (NULL != covquant) pfree(covquant);
+		pfree(covquant);
 		quantile_llist_destroy(&qlls, qlls_count);
 		SPI_finish();
@@ -2646,7 +2636,6 @@
 		char *sql = NULL;
 		int spi_result;
 		Portal portal;
 		HeapTuple tuple;
 		Datum datum;
@@ -2781,7 +2770,7 @@
 		if (NULL == sql) {
 			SPI_finish();
 			if (search_values_count) pfree(search_values);
@@ -2807,13 +2796,12 @@
 				SPI_finish();
@@ -2834,7 +2822,7 @@
 			if (!raster) {
 				SPI_finish();
@@ -2853,7 +2841,7 @@
 				SPI_finish();
@@ -2871,7 +2859,7 @@
 				SPI_finish();
@@ -2889,7 +2877,7 @@
 			if (NULL == vcnts || !count) {
 				elog(NOTICE, "Cannot count the values for band at index %d", bandindex);
 				SPI_finish();
@@ -2906,7 +2894,7 @@
 				covvcnts = (rt_valuecount) SPI_palloc(sizeof(struct rt_valuecount_t) * count);
 				if (NULL == covvcnts) {
 					SPI_finish();
@@ -2942,14 +2930,12 @@
 					else {
 						covcount++;
 						covvcnts = SPI_repalloc(covvcnts, sizeof(struct rt_valuecount_t) * covcount);
-						if (NULL == covvcnts) {
+						if (!covvcnts) {
 							SPI_finish();
-							if (NULL != covvcnts) free(covvcnts);
 							MemoryContextSwitchTo(oldcontext);
 							elog(ERROR, "RASTER_valueCountCoverage: Cannot change allocated memory for value counts of coverage");
@@ -2971,7 +2957,7 @@
 		SPI_finish();
Modified: trunk/raster/test/cunit/cu_mapalgebra.c
--- trunk/raster/test/cunit/cu_mapalgebra.c	2018-07-13 23:30:57 UTC (rev 16644)
+++ trunk/raster/test/cunit/cu_mapalgebra.c	2018-07-14 22:00:33 UTC (rev 16645)
@@ -240,8 +240,8 @@
 	/* 0,2 */
 	else if (
-		arg->dst_pixel[0] == 3 &&
-		arg->dst_pixel[1] == 3
+		arg->dst_pixel[0] == 0 &&
+		arg->dst_pixel[1] == 2
 		CU_ASSERT_DOUBLE_EQUAL(arg->values[0][0][0], 16, DBL_EPSILON);
 		CU_ASSERT_EQUAL(arg->nodata[0][0][0], 0);
