[postgis-tickets] r16660 - Fix TopologyException in Raster Instersection
Darafei
komzpa at gmail.com
Sun Jul 22 05:22:28 PDT 2018
Author: komzpa
Date: 2018-07-22 05:22:27 -0700 (Sun, 22 Jul 2018)
New Revision: 16660
trunk/NEWS
trunk/raster/rt_pg/rtpostgis.sql.in
Raster _st_intersects was doing ST_Collect of polygons building each pixel,
which led to invalid geometry and TopologyException.
Thanks Vinícius A.B. Schmidt for reporting and testing solutions.
Closes #4132
Modified: trunk/NEWS
--- trunk/NEWS 2018-07-22 05:00:46 UTC (rev 16659)
+++ trunk/NEWS 2018-07-22 12:22:27 UTC (rev 16660)
@@ -4,6 +4,8 @@
- #4115, Fix a bug that created MVTs with incorrect property values under
parallel plans (Raúl Marín).
- #4120, ST_AsMVTGeom: Clip using tile coordinates (Raúl Marín).
+ - #4132, ST_Intersection on Raster now works without throwing TopologyException
+ (Vinícius A.B. Schmidt, Darafei Praliaskouski)
See PostGIS 2.5.0 section for full details
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in 2018-07-22 05:00:46 UTC (rev 16659)
+++ trunk/raster/rt_pg/rtpostgis.sql.in 2018-07-22 12:22:27 UTC (rev 16660)
@@ -6434,7 +6434,7 @@
RETURN TRUE;
END IF;
- SELECT @extschema at .ST_Collect(t.geom) INTO _geom FROM @extschema at .ST_PixelAsPolygons(rast, nband) AS t;
+ SELECT @extschema at .ST_Buffer(@extschema at .ST_Collect(t.geom), 0) INTO _geom FROM @extschema at .ST_PixelAsPolygons(rast, nband) AS t;
RETURN @extschema at .ST_Intersects(geom, _geom);
END;
$$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL
