[postgis-tickets] r16661 - Fix raster regression on Raspberry Pi.
Darafei komzpa at gmail.com
Sun Jul 22 05:17:50 PDT 2018
Author: komzpa
Date: 2018-07-22 17:17:50 -0700 (Sun, 22 Jul 2018)
New Revision: 16661
   trunk/raster/rt_core/rt_pixel.c
   trunk/raster/rt_core/rt_serialize.c
   trunk/raster/rt_core/rt_wkb.c
   trunk/raster/test/regress/tickets.sql
   trunk/raster/test/regress/tickets_expected
A signed NODATA value was assigned to unsigned variable.
On Intel that was reversible, on ARM and PPC it replaced all negatives with 0.
Thanks to Alina Dolgikh for supporting me: https://www.patreon.com/komzpa
Closes #4102
Closes https://github.com/postgis/postgis/pull/276
Modified: trunk/raster/rt_core/rt_pixel.c
--- trunk/raster/rt_core/rt_pixel.c	2018-07-22 12:22:27 UTC (rev 16660)
+++ trunk/raster/rt_core/rt_pixel.c	2018-07-23 00:17:50 UTC (rev 16661)
@@ -151,13 +151,13 @@
 			return (double) rt_util_clamp_to_1BB((double) CHAR_MIN);
 		case PT_2BUI: {
-			return (double) rt_util_clamp_to_2BUI((double) CHAR_MIN);
+			return 0;
 		case PT_4BUI: {
-			return (double) rt_util_clamp_to_4BUI((double) CHAR_MIN);
+			return 0;
 		case PT_8BUI: {
-			return (double) rt_util_clamp_to_8BUI((double) CHAR_MIN);
+			return 0;
 		case PT_8BSI: {
 			return (double) rt_util_clamp_to_8BSI((double) SCHAR_MIN);
@@ -166,13 +166,13 @@
 			return (double) rt_util_clamp_to_16BSI((double) SHRT_MIN);
 		case PT_16BUI: {
-			return (double) rt_util_clamp_to_16BUI((double) SHRT_MIN);
+			return 0;
 		case PT_32BSI: {
 			return (double) rt_util_clamp_to_32BSI((double) INT_MIN);
 		case PT_32BUI: {
-			return (double) rt_util_clamp_to_32BUI((double) INT_MIN);
+			return 0;
 		case PT_32BF: {
 			return (double) -FLT_MAX;
Modified: trunk/raster/rt_core/rt_serialize.c
--- trunk/raster/rt_core/rt_serialize.c	2018-07-22 12:22:27 UTC (rev 16660)
+++ trunk/raster/rt_core/rt_serialize.c	2018-07-23 00:17:50 UTC (rev 16661)
@@ -629,7 +629,12 @@
 				ptr += 1;
 				break;
-			case PT_16BSI:
+			case PT_16BSI: {
+				int16_t v = band->nodataval;
+				memcpy(ptr, &v, 2);
+				ptr += 2;
+				break;
 			case PT_16BUI: {
 				uint16_t v = band->nodataval;
 				memcpy(ptr, &v, 2);
@@ -636,7 +641,12 @@
 				ptr += 2;
 				break;
-			case PT_32BSI:
+			case PT_32BSI: {
+				int32_t v = band->nodataval;
+				memcpy(ptr, &v, 4);
+				ptr += 4;
+				break;
 			case PT_32BUI: {
 				uint32_t v = band->nodataval;
 				memcpy(ptr, &v, 4);
Modified: trunk/raster/rt_core/rt_wkb.c
--- trunk/raster/rt_core/rt_wkb.c	2018-07-22 12:22:27 UTC (rev 16660)
+++ trunk/raster/rt_core/rt_wkb.c	2018-07-23 00:17:50 UTC (rev 16661)
@@ -592,7 +592,12 @@
 				ptr += 1;
 				break;
-			case PT_16BSI:
+			case PT_16BSI: {
+				ptr += 2;
+				break;
 			case PT_16BUI: {
 				memcpy(ptr, &v, 2);
@@ -599,7 +604,12 @@
 				ptr += 2;
 				break;
-			case PT_32BSI:
+			case PT_32BSI: {
+				ptr += 4;
+				break;
 			case PT_32BUI: {
 				memcpy(ptr, &v, 4);
Modified: trunk/raster/test/regress/tickets.sql
--- trunk/raster/test/regress/tickets.sql	2018-07-22 12:22:27 UTC (rev 16660)
+++ trunk/raster/test/regress/tickets.sql	2018-07-23 00:17:50 UTC (rev 16661)
@@ -117,3 +117,7 @@
  #3055 ST_Clip() on a raster without band crashes the server
 SELECT ST_SummaryStats(ST_Clip(ST_MakeEmptyRaster(42, 42, 0, 0, 1.0, 1.0, 0, 0, 4269), ST_MakeEnvelope(0, 0, 20, 20, 4269)));
+-- #4102 negative nodata values don't apply on Raspberry Pi
+SELECT '#4102.1', ST_BandNoDataValue(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 0), 1, '16BSI', 0, -10), 1) AS rast;
+SELECT '#4102.2', ST_BandNoDataValue(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 0), 1, '32BSI', 0, -10), 1) AS rast;
Modified: trunk/raster/test/regress/tickets_expected
--- trunk/raster/test/regress/tickets_expected	2018-07-22 12:22:27 UTC (rev 16660)
+++ trunk/raster/test/regress/tickets_expected	2018-07-23 00:17:50 UTC (rev 16661)
@@ -14,3 +14,5 @@
 ERROR:  new row for relation "test_raster_scale_small" violates check constraint "enforce_scaley_rast"
 NOTICE:  Input raster is empty or has no bands. Returning empty raster
 NOTICE:  Invalid band index (must use 1-based). Returning NULL
+#4102.1|-10
+#4102.2|-10
