[postgis-tickets] [PostGIS] #4085: ERROR: GEOSIntersects: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
PostGIS trac at osgeo.org
Tue Jul 24 14:18:30 PDT 2018
  Reporter:  Gluchich  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 2.4.5
 Component:  postgis   |    Version:  2.4.x
Resolution:  wontfix   |   Keywords:  non-finite numbers
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 Returning NULL on an exception is out of scope. As noted, you can check
 invalidity yourself and strip those inputs from the query, or make an
 exception catching wrapper.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4085#comment:2>
