[postgis-tickets] r16670 - Clarify retry logic in lwgeom_offsetcurve
Daniel Baston
dbaston at gmail.com
Wed Jul 25 01:15:44 PDT 2018
Author: dbaston
Date: 2018-07-25 13:15:43 -0700 (Wed, 25 Jul 2018)
New Revision: 16670
trunk/liblwgeom/lwgeom_geos.c
Closes https://github.com/postgis/postgis/pull/273
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c 2018-07-24 20:55:20 UTC (rev 16669)
+++ trunk/liblwgeom/lwgeom_geos.c 2018-07-25 20:15:43 UTC (rev 16670)
@@ -1456,7 +1456,6 @@
int32_t srid = RESULT_SRID(geom);
LWGEOM *result = NULL;
- LWGEOM *noded = NULL;
if (srid == SRID_INVALID) return NULL;
if (lwgeom_dimension(geom) != 1)
@@ -1465,41 +1464,40 @@
return NULL;
- while (!result)
+ switch (geom->type)
- switch (geom->type)
+ case LINETYPE:
+ result = lwline_offsetcurve(lwgeom_as_lwline(geom), size, quadsegs, joinStyle, mitreLimit);
+ break;
+ case COLLECTIONTYPE:
+ case MULTILINETYPE:
+ result = lwcollection_offsetcurve(lwgeom_as_lwcollection(geom), size, quadsegs, joinStyle, mitreLimit);
+ break;
+ default:
+ lwerror("%s: unsupported geometry type: %s", __func__, lwtype_name(geom->type));
+ return NULL;
+ if (!result)
+ /* Node the input geometry and try again */
+ LWGEOM* noded = lwgeom_node(geom);
+ if (!noded)
- case LINETYPE:
- result = lwline_offsetcurve(lwgeom_as_lwline(geom), size, quadsegs, joinStyle, mitreLimit);
- break;
- case COLLECTIONTYPE:
- case MULTILINETYPE:
- result = lwcollection_offsetcurve(lwgeom_as_lwcollection(geom), size, quadsegs, joinStyle, mitreLimit);
- break;
- default:
- lwerror("%s: unsupported geometry type: %s", __func__, lwtype_name(geom->type));
+ lwerror("%s: cannot node input", __func__);
return NULL;
- if (result)
- return result;
- else if (!noded)
- noded = lwgeom_node(geom);
- if (!noded)
- lwfree(noded);
- lwerror("lwgeom_offsetcurve: cannot node input");
- return NULL;
- geom = noded;
- else
- lwerror("lwgeom_offsetcurve: noded geometry cannot be offset");
- return NULL;
+ result = lwgeom_offsetcurve(noded, size, quadsegs, joinStyle, mitreLimit);
+ lwfree(noded);
+ if (!result)
+ lwerror("%s: noded geometry cannot be offset", __func__);
+ return NULL;
return result;
